It is currently Fri May 29, 2026 12:44 pm
PostPosted: Wed Jan 12, 2022 7:37 am
Hi,
I'm a new member that recently purchased a 76 LUV all stock with about 85K miles on it. Got is running and seems to run ok but there seems to be an excessive amount of pressure in the engine. When I remove the oil filler cap with the engine running there is air/pressure/blow by coming out of the valve cover. Do I have a crack in the head? Emissions system problem? Has anyone experienced anything like this before?
Thanks,
Dave
PostPosted: Thu Jan 13, 2022 11:04 pm
Do a compression test on each cylinder. My first guess would be excessive blow-by from a severely worn cylinder, broken piston rings or possibly broken piston.
Tom
PostPosted: Fri Jan 14, 2022 7:05 am
Thanks Tom I will check into that.
PostPosted: Tue Jan 25, 2022 4:46 pm
Compression is good. Lowest cylinder was 120. The other 3 were 145-150
Could it be a blown head gasket?
PostPosted: Sat Jan 29, 2022 8:52 pm
Yes
Tom
PostPosted: Sun Feb 20, 2022 12:24 pm
These engines run with an abnormal amount of pressure. Every one of them I've owned do that. I don't know why, they just do that.
PostPosted: Fri Feb 25, 2022 4:33 pm
Ok thanks. I guess I'll just run it and see what happens.
Users browsing this forum: Baidu [Spider] and 56 guests
