It is currently Wed Jun 10, 2026 12:23 am
PostPosted: Mon Feb 22, 2021 7:24 am
Just curious if anyone has replaced a fuel pump on an 81 LUV gas truck? Were you able to find an OEM or did you use a universal aftermarket pump?
THanks
PostPosted: Tue Feb 23, 2021 12:06 am
Went through about 4 "OEM" pumps from O Reillys and AutoZone before I just caved and spent the money on a Holley Red.
As far as I can tell, the Ethanol in today's fuel ruins the cheap pumps.
Some of them only lasted 6 months.
PostPosted: Tue Feb 23, 2021 5:42 am
Yikes! Thanks for the information. The Red is a little more pricey over the OEM pumps. Anyone try the Speedway Red pump?
PostPosted: Tue Feb 23, 2021 2:02 pm
There are quite a few negative reviews on that speedway pump.
Here’s a comparable unit for a decent price. https://www.speedwaymotors.com/Sniper-8 ... 31302.html
You can get a bad pump from a lot of manufacturers. I had a walbro pump, a really expensive one, be dead on arrival and I’ve had good luck with cheapo Amazon Chinese pumps.
Users browsing this forum: Baidu [Spider] and 48 guests
