It is currently Sat May 23, 2026 9:56 pm
 Post subject: Extensive Cab Repair
PostPosted: Sun Jan 10, 2021 4:45 pm
What's the most extensive cab repair you done to your LUV?
I have three cabs, all with differing rust issues. One has pin holes in the back panel, another has previous mods and welds that are now rusted and the third has rust holes in the roof, door window channels, rockers and floor.
63200635288__E34B8B03-B47F-430A-9EBA-6AE9CF570B9A.HEIC.jpeg [ 482.99 KiB | Viewed 13447 times ]
This is by far the best of the 3
63200637187__C9CEFD2B-60C7-4238-979B-516BB9000299.HEIC.jpeg [ 480.77 KiB | Viewed 13447 times ]
63200638216__7D0E705D-2BC4-4906-A83E-DB034A938A4A.HEIC.jpeg [ 347.58 KiB | Viewed 13447 times ]
 Post subject: Re: Extensive Cab Repair
PostPosted: Mon Jan 11, 2021 10:23 am
Three cabs and all of them have rust holes in the lower portion of the radiator support. Does this seem like a common issue?
PostPosted: Tue Jan 12, 2021 8:32 am
How the hell do you get rust on the top of the cab? (From that antenna hole?)
PostPosted: Tue Jan 12, 2021 8:46 am
From what I can tell, the white cab was a service truck, original title is from a local oil company. So, right, probably an antenna or light bar of some sort.
PostPosted: Mon Jan 25, 2021 8:51 am
Anyone ever replace the rockers on a Luv? I'm toying with the idea of repairing the White. It all boils down to the back cab panel. Theres a structural cab brace in the light blue cab that a little rusty. The White cabs back panel is good.
Thoughts?
Users browsing this forum: Google [Bot] and 21 guests
