It is currently Sat May 23, 2026 3:24 pm
PostPosted: Wed Dec 02, 2020 5:08 pm
hey there people. my drivers side door lock is super loose. the rattle of the engine running or if you dont close the door hard enough usually ends up with the door "half locking" where you kinda have to open the door and then slam it and open it again to get it to fully open. its usually part of my routine now to pull up on the lock switch whenever i want to get out because it falls down so much. is there a way to stiffen it up? the truck was sitting since 2001 and only had about 88k on it when i got it so i wouldnt think the actual lock was worn out yet... i should start bringing an extra set of keys with me so i dont accidentally lock myself out of it in town or somthin
1976 LUV, 0-60 eventually.............
put er in the ketchup!!!!
