It is currently Sat May 23, 2026 6:54 pm
 Post subject: Oil Cooler
PostPosted: Fri Jul 03, 2020 11:22 am
So I have been looking around with no luck for this part. My oil cooler is completely plugged and I can't replumb it. I own the 2.2 diesel sport. I have been looking under isuzu pup as well of course.
 Post subject: Re: Oil Cooler
PostPosted: Sat Jul 04, 2020 12:55 pm
What country are you in?
What's "plugged"? Oil, or coolant?
PostPosted: Tue Jul 07, 2020 3:36 pm
I'm in the USA, its plugged with what I can assume is oil so bad that it created back pressure in the system and split a few pipes.
PostPosted: Tue Jul 07, 2020 3:56 pm
Sorry, that doesn't add up. There are no oil pipes feeding the oil cooler.
So how about let's talk about the symptoms. What "pipes" split?
PostPosted: Thu Jul 09, 2020 5:50 pm
What year LUV? Are talking engine oil cooler or automatic transmission oil cooler?
PostPosted: Thu Jul 09, 2020 6:06 pm
Ron, none of the diesels had transmission coolers. All have an oil cooler in the filter base. Generally, if they fail, it's due to coolant leakage. I've never heard of one clogging up (other than this one).
