It is currently Mon May 25, 2026 2:46 am
PostPosted: Sat Apr 25, 2020 7:36 am
im toying around with doing this for the winter months while my truck in storage, what I was thinking was making one out of plywood and sealing t from moisture then covring the top with fiberglass and having it painted to match the body color I want it to be flush with the bedsides then make some sort of a hinge with gas shocks? does this sound crazy? or does anyone ahve any other ideas?
use this page for delivery flowers Kazakhstan
PostPosted: Mon Apr 27, 2020 5:09 am
Makes sense to me. Put rubber weather strip around where it sits on the bed lip and it may even be water tight. Latches around perimeter where it has tie down loops and youre set
PostPosted: Mon Apr 27, 2020 12:42 pm
By the time you do all that, and brace it to keep it from sagging, you probably could have a sheet of aluminum sheared for the same money...
PostPosted: Tue Apr 28, 2020 12:12 am
I made this opening semi hard tonneau cover style for my step-side bed
the Notch opening @ the front of bed have fork mounts so i can mount 2 bikes on top of this. 34
44983290_1369741213156912_7940107199756369920_o.jpg [ 372.52 KiB | Viewed 14514 times ]
