It is currently Sat Dec 20, 2025 9:43 pm
 Post subject: GEN Light Flickering
PostPosted: Wed Jul 17, 2019 9:25 am
I have the GEN light coming on mostly on the first trip of the day. The trip home from work it barely comes on, if at all. The truck runs like normal except when the GEN light comes on the headlights get brighter in connection with GEN light.
Alternator? Voltage regulator? Any help would be appreciated.
1978 Chevy LUV
Purchased Aug. 2014
Second owner
2006 Honda Shadow LX
Purchased July 2006
Original owner
"Not all those who wander are lost" - J.R.R. Tolkien
:twisted:
 Post subject: Re: GEN Light Flickering
PostPosted: Fri Jul 19, 2019 7:02 am
GEN light coming on more frequent now.
I see it comes on the most at higher RPM's, mostly before shifting and then when cruising in 4th gear. This morning's ride to work it was on solid for a few minutes for the first time since this has been happening.
I suppose I will replace alternator on Sunday, I hear these trucks burn through them and my current one is four years old.
1978 Chevy LUV
Purchased Aug. 2014
Second owner
Purchased July 2006
Original owner
:twisted:
PostPosted: Fri Jul 19, 2019 9:00 am
I had a glowing alt light last year and it was the alternator.
PostPosted: Fri Jul 19, 2019 12:11 pm
Yeah, calling Napa about getting an alternator to swap out this weekend...
1978 Chevy LUV
Purchased Aug. 2014
Second owner
Purchased July 2006
Original owner
:twisted:
PostPosted: Fri Jul 19, 2019 3:40 pm
Before replacing the alternator, I'd try replacing the brushes. They're about $10, if they're like the ones on my diesel. It's about an hour's work including soldering the terminals onto the leads (assuming they're accessible without removing the alternator). The ones for my diesel were not Isuzu-specific, they were generic. So they shouldn't be hard to find.
PostPosted: Sun Jan 05, 2020 4:44 pm
Here is a video of the dash. Any ideas?
https://youtu.be/dvOtI_1YlTA
1978 Chevy LUV
Purchased Aug. 2014
Second owner
Purchased July 2006
Original owner
:twisted:
PostPosted: Sun Jan 05, 2020 9:41 pm
I would change the regulator at the same time as the alternator. They kind of go together like points and condenser.
PostPosted: Mon Jan 06, 2020 4:17 pm
Regulator and alternator are brand new. This is even the second new regulator trying to figure it out.
1978 Chevy LUV
Purchased Aug. 2014
Second owner
Purchased July 2006
Original owner
:twisted:
PostPosted: Mon Jan 06, 2020 5:29 pm
Most new regulators now are crappily built. If it works, the voltage could be too low or high. They are adjustable. I am having trouble typing, but a search on this sight for regulator adjusting should help you out...
PostPosted: Tue Jan 07, 2020 11:26 am
not trying to be a dik but are you keeping the regulator to keep an entirely stock truck stock,instead of just canning all that stuff and installing (with some bracket building) a modern alt with internal regulation?
PostPosted: Thu Jan 09, 2020 8:52 am
Not trying to keep anything stock, just want it to be a reliable truck to get to work.
I am not very mechanically inclined, so I wouldn't know where to start doing something like that.
1978 Chevy LUV
Purchased Aug. 2014
Second owner
Purchased July 2006
Original owner
:twisted:
PostPosted: Thu Jan 09, 2020 10:47 am
Maybe try following the wire or look at the schematic, and see where it goes. Could have a loose connection somewhere for the light. IDK, just throwing ideas out there. If it is charging, it should be reliable to drive, just with a flickering light. But that's annoying I know.
PostPosted: Thu Jan 09, 2020 9:26 pm
ok, thanks 007. parts for these trucks are getting way harder to come by,thats for sure. At some point things are going to have to be adapted to fit, to keep on the road. I dont have that problem because my 79 isnt road worthy,just a retirement project to mess with when i feel the need to cut or modify something. I put a Chevy 1 wire 110amp alternator on mine,but I dont have any dash lights (or dash) so it was pretty simple. a smaller Japanese alt would have been easier to bracket in,but I had the big case Chevy laying around..good luck with the flicker. Im sure these guys will get you sorted soon.
PostPosted: Tue Jan 14, 2020 6:59 pm
Is there any alternators that have the regulator installed out there that fit the wires that are on the stock truck?
I am cool with trying to fabricate a mount for the alternator, just don't know which alternator I should get that will work for the truck.
1978 Chevy LUV
Purchased Aug. 2014
Second owner
Purchased July 2006
Original owner
:twisted:
Users browsing this forum: Google [Bot] and 24 guests
