It is currently Sun Jun 28, 2026 6:29 am
 Post subject: Fuel pump issues?
PostPosted: Tue Jul 16, 2019 9:07 pm
Hey guys, I have a 79 luv 4x4 and I recently replaced the fuel pump, about two months later I had to replace it again. It seems to be running fine, but the pump is getting pretty hot, I’m not sure how to fix it, or if I’m using the rite pump, I’m also wondering if my gas tank isn’t venting properly
If anybody can give me some tips that would be awesome, thanks!
 Post subject: Re: Fuel pump issues?
PostPosted: Wed Jul 17, 2019 11:00 am
Are you sure it's getting a good ground? Sand/scrape the mounting area or the ground wire connection if it has one.
The pump on mine does get pretty warm.
Are you sure the fuel is getting from the tank to the pump well? Could have a problem that is starving the pump and burning it out.... or a blockage on the pressure side also.
PostPosted: Wed Jul 17, 2019 7:33 pm
Could be the Ethanol they put in gasoline now?
Users browsing this forum: Google [Bot] and 45 guests
