It is currently Sun Mar 22, 2026 2:49 pm
PostPosted: Tue Feb 05, 2019 5:37 pm
drip-down (leak-down) test results were all below 13% (all cylinders), rings seem good
newly rebuilt stock engine, bored 40-over
oil continues to get to top of engine. black spot on new air filter on battery-side/edge of air filter, a little oil pooling in crevices outside engine, must be lots of crankcase pressure, any ideas on what to do? tk u, bc
PostPosted: Tue Feb 05, 2019 9:52 pm
Sounds dumb, but check your oil level. It sounds to me like you've got 2 or 3 too many quarts of oil in there and it's being slung all over the place by the timing chain.
How many quarts did you put in there when you went to go fire it up? It should only take 4 total, including filling the new filter.
PostPosted: Tue Feb 05, 2019 10:11 pm
oil is normal filled, but after a couple of hours of driving, it's down to bottom of dipstick.
