It is currently Sun Jun 07, 2026 12:47 am
PostPosted: Sat Sep 15, 2018 8:06 pm
Hi there folks! My '79 4x4 manual LUV has a slow oil leak from the 4x4 transfer case. After staring at both the Haynes manual and the case itself, I believe it's probably due to a bad oil seal on the front output shaft. Possibly the gasket on the back of the case, but I'm leaning towards the oil seal. I'll probably replace both anyways.
I cleaned off the oil so I can hopefully know for sure where it's leaking from once I let it leak overnight into a container in the garage. In the picture, the red dot is where it forms droplets and leaks off onto the ground. Red line indicates the path I _think_ it's taking.
https://imgur.com/a/wlKN1s7
https://imgur.com/a/MsPXxb0
Couple questions:
* Does my theory sound right to y'all?
* How hard is this repair? From a quick glance it seems mostly straightforward as long as I keep track of things for re-assembly.
* I think this is the replacement seal I need: https://www.google.com/search?q=94028351+oil+seal. Look right to y'all? Any alternative or easy substitutions that will work well for this seal?
Thanks for the help -- mostly newbie mechanic here. Moving up from vintage mopeds to this LUV that's been sitting for a few years.
PostPosted: Sat Sep 15, 2018 9:47 pm
Looking quickly at the parts manual I think it may be a pretty detailed job to replace the seal. I am not sure if there is a preload involved on the bearings. Sometimes leaks look worse then they are, not saying leaks shouldn’t be addressed though. I would clean the area thourghly. I personally use baby powder all over the area I suspect a leak and run it, if it leaks the oil will leave you a line straight to the problem area. You might be surprised how little it’s actualy leaking.
The baby powder idea came from searching for leaks in helicopter engine bays.
PostPosted: Sun Sep 16, 2018 12:21 pm
Yeah it is a very slow leak so not the end of the world, but I would like to get it fixed at some point. Thanks for the tip on the baby powder -- will give that a try.
