It is currently Sat Jun 20, 2026 3:02 pm
 Post subject: Stearing box oil?
PostPosted: Tue Jan 30, 2018 4:48 pm
I started working on my 75 step side again.
Looks like the PO put STP in the gearbox. I just thought it was the small grant wheel. It leaks from the seal where the shaft goes into the box.
How can I drain the STP-Oil that is in there? What should I use for oil in it? 30w?
Is that seal available? Can I remove it and see if I can match it up with something else if it is not available?
Yes, I am still alive and kicking.
PapaG. 8O
 Post subject: Re: Stearing box oil?
PostPosted: Tue Jan 30, 2018 7:29 pm
Without looking at the book says, I would guess 85/90w gear oil.
PostPosted: Wed Jan 31, 2018 10:04 am
Ok. on the oil.
Need the other information please
PostPosted: Thu Feb 01, 2018 12:37 am
I will get my LAP to look it up..
PostPosted: Mon Mar 12, 2018 11:00 pm
You might also look at the 75 Izuzu book for a part number.
