It is currently Sat Apr 18, 2026 10:12 am
 Post subject: Valve Cover Bolts needed
PostPosted: Sun Nov 12, 2017 2:02 pm
I've looked around... been to NAPA, O'Reilly, and a local hardware store with a good selection and cannot find the replacement bolts for the stock valve cover. The PO managed to cross thread one of them and when i tried to take it off i chewed it up pretty bad. I was checking the timing (as the truck still will turn over and gas is good, but won't catch).
I can easily find the grommets and the gasket... but nothing on the bolts. Anyone have any ideas where to get a new set? I really just need one, but it'd be nice to get a new set.
Thanks in advance.
1980 Chevy Luv (SBC350 and TH350 mounted!) front suspension install, trooper rear end with 4.10 gearing, needs driveline, brakes, and getting it running!
1968 Datsun Roadster - happy as ever!
1991 Nissan 300zx Twin Turbo (daily as possible)
PostPosted: Wed Nov 15, 2017 9:55 pm
Thanks in advance.
If you can't find anything, I am parting out a couple Luvs, I can get you some used bolts.
Users browsing this forum: No registered users and 119 guests
