It is currently Sat Jun 06, 2026 11:47 pm
 Post subject: Chevy LUV engine
PostPosted: Fri Oct 13, 2017 12:09 am
Hi guys, did the LUV engine get redesigned in 1978-80? Do the '78-'80 models have the starter on the drivers side?....or all the engines the same through '80? How about the clutch? Are they all hydraulic? Thanks Don.
 Post subject: Re: Chevy LUV engine
PostPosted: Fri Oct 13, 2017 8:37 am
I will look it up when I get home from work. I think everything changed 75-76 and remained the same until they changed a few things again in 81.
Both my 79 and 80 were/are cable clutch.
PostPosted: Fri Oct 13, 2017 10:34 am
72-75 had intake and exhaust on same side. 76-82 had intake and exhaust on opposite sides. There are a lot of starter changes and cable / hydraulic differences that I don't know by heart. My 76 had a hydraulic clutch and my 80 4x4 had a cable clutch.
Afaik all the motor components from 76-82 interchange.
PostPosted: Fri Oct 13, 2017 1:29 pm
There is also the option of downloading the parts list from this site and doing research that way. That's where I was going to get my information for you from.
http://www.luvtruck.com/pdf/Chevy_1972- ... _parts.exe
PostPosted: Sun Oct 15, 2017 1:12 am
THanks .....My '77 has hydraulic clutch with slave cylinder on passenger side. Starter is also on passenger side. Flow through head with exhaust on drivers side. Several years ago I bought a supposed 1977 LUV transmission from B&R Auto Wrecking in Albany, Oregon. When I opened the crate I found the starter to be on the drivers side of the LUV> Couldn't use it. Now I'm not sure if it is a LUV transmission at all. This is the reason for my query.
PostPosted: Sun Oct 15, 2017 8:55 am
viewtopic.php?p=13556#p13556
viewtopic.php?p=197927#p197927
Both of these posts I've linked have information regarding this.
PostPosted: Wed Oct 18, 2017 3:43 pm
Thanks Drummer, That was just the right info. Cleared everything up.
Users browsing this forum: No registered users and 74 guests
