It is currently Sun Jun 07, 2026 12:47 am
 Post subject: Air conditioning
PostPosted: Fri Sep 15, 2017 12:04 pm
Is anyone out there running A/C in their stock LUVS? If so, what compressor are you using? Thanks Don
 Post subject: Re: Air conditioning
PostPosted: Fri Sep 15, 2017 2:41 pm
My stock LUV is actually a stock P'up, but I'm using a genuine Isuzu compressor. The entire system was factory installed.
PostPosted: Fri Sep 15, 2017 5:48 pm
MY '77 LUV is missing the compressor and the mounting brackets. Been thinking about getting something fixed up to cool the luv but can't find where the compressor was mounted. Looks like there is no room at the front of the engine for the mount and compressor.
PostPosted: Fri Sep 15, 2017 11:58 pm
I have a parts truck that has a aftermarket system on it. I will take a picture tomorrow.
PostPosted: Sat Sep 16, 2017 7:53 am
When working with an old vehicle, sometimes you have to use aftermarket components and have someone fabricate the lines for you. I had a local guy make new lines for mine. All the local mechanics know him, and he does work for a lot of the dealers as well.
Since you're in Phoenix, you might want to check with Arizona Mobile Air in Scottsdale for any parts you need. I've bought from them before. They seem to target pros, but anyone can buy from them.
PostPosted: Sat Sep 16, 2017 1:16 pm
I had a bad compressor and could not find a replacement anywhere. Ended up having mine rebuilt at a small shop in my area that does that stuff.
PostPosted: Sun Sep 17, 2017 2:58 pm
Thanks guys....I'm eager to view your replies.
PostPosted: Tue Sep 11, 2018 11:04 pm
would someone mind posting some pictures of stock a/c on a luv? I can get an underdash evap/vent system. I want to see if I can find a bracket and compressor.. thanks in advance..
PostPosted: Wed Sep 12, 2018 12:50 pm
What year? Gas, or diesel?
PostPosted: Wed Jan 30, 2019 8:30 pm
Guys! I just bought a 1979 with factory air, but I too, am missing the compressor and mounts. I found the compressors on Rock Auto but I don't know which one to buy there are two types. Any help is greatly appreciated. Please PM me with any advise. Thanks!!!
