It is currently Mon Nov 03, 2025 7:30 am
Post new topic Reply to topic  [ 79 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: Fishing truck
PostPosted: Tue Feb 07, 2017 1:17 pm
Been a while since I posted. I sold Voodoo so I could concentrate on my other projects so I have to get this one going so I have a ride. I finished the cage and put in a hinged door bar on the passenger side for easier access. I built a panel for the msd and relays. Hopefully keep away from the rats nest I had with the other truck.
Getting the fender extended so we can start on body work.
I got the bars done in the bed and fitting in the fuel system.
PostPosted: Wed Feb 08, 2017 11:18 am
Why put the swing out bar on the passengerside ?
PostPosted: Wed Feb 08, 2017 1:13 pm
That is so I can work on the electronics. I used to have a really hard time accessing the wiring and such.
PostPosted: Wed Feb 08, 2017 4:38 pm
looking good sir. Hate to see Voodoo go.
PostPosted: Fri Feb 10, 2017 6:27 pm
I hear ya but she is still out there. I sold Voodoo to Mark who drove her for quite a while.
I started working on the fuel system. I got the pump mounted and the intake hoses ran.
Mounted the fuel rail.
PostPosted: Thu Feb 16, 2017 3:29 pm
Started getting to work on the body, test fitting the fenders. They fit pretty good, starting to look like a truck again.
PostPosted: Wed Mar 01, 2017 5:41 am
Still working on the front end. I have a new hood that sat out in the rain before I got it. Lots of surface rust and the front edge was rusted out. Funny thing I figured out, the valance has the same exact contour as the hood. I had a spare so it got sacrificed. Now how the get the surface rust off.
PostPosted: Wed Mar 01, 2017 5:49 am
I got the fuel lines piped in and the throttle linkage done.
Getting the dash lined out and got the steering wheel mounted.
PostPosted: Fri Mar 03, 2017 1:43 pm
looking good sir. How far back is the motor set?
PostPosted: Sat Mar 04, 2017 4:33 pm
3.5 Same as the back axle. Basically I moved the center of gravity back. 8)
PostPosted: Fri Mar 17, 2017 7:24 pm
Just about got the dash done. Still need some tweaking but its starting to come together.
I striped all the old paint off of the drivers fender. Amazing it looks really good without all the crud on it.
PostPosted: Mon May 01, 2017 8:35 am
I have been making progress. Getting the interior ready for paint. I have new tires and wheels for the front etc. I will take some more pictures later. Here is the trans cooler mounted in the bed. I made some brackets to set it away from the wall. Should I cut a hole for airflow?
PostPosted: Mon May 01, 2017 8:50 pm
maybe put a fan on the cooler? how big of a hole do you want to cut.
Question about your pump return. will it cause issues being next to the outlet???
PostPosted: Sun May 07, 2017 12:31 pm
I think I will look for a little fan probably doesnt need much.
Well here we go. Final assembly on the rear end. Should have the punkin and brakes installed this next week.
PostPosted: Fri Aug 04, 2017 8:00 am
Test
PostPosted: Fri Aug 04, 2017 8:02 am
Well I`ll be it worked. If you paste ~original in between jpg and [/IMG][/URL] your photobucket pics show back up. Dont know for how long...
PostPosted: Fri Aug 04, 2017 8:11 am
LOL
PostPosted: Wed Jan 31, 2018 10:44 pm
I will post some pictures soon but I am ready to go test. It is still in primer but is running and driving. Maybe next weekend.
PostPosted: Wed Oct 24, 2018 11:45 am
Well I took it out a few months ago and lost a freeze plug in the pits. I pulled the engine and repaired it and reinstalled. With a bum hip that is killing me and the summer heat I let it sit for a bit. But last weekend we took it out. Ended up running a 710@93 with no nitrous on a 53 year old basically stock 327. We are shooting for the 7.00 class so its real close already.
I cant figure out how to post the video. Maybe this will work.
https://www.facebook.com/10000333846193 ... 3338461934
