It is currently Mon Jun 15, 2026 10:49 pm
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Jul 21, 2017 8:27 pm
Are talking about the rubber around the outside edge of the doors? Here we call that door weatherstrip, They are glued on.
PostPosted: Sat Jul 22, 2017 4:41 am
No i am talking about these
PostPosted: Sat Jul 22, 2017 7:39 pm
Those are held onto the door by internal clips, you can get them off by carefully prying up on them. I can take a picture of the underside of one if you need.
PostPosted: Sat Jul 22, 2017 8:01 pm
yes please,that would help me a lot.
PostPosted: Sun Jul 23, 2017 10:43 am
Will try to get you some pics later today.
PostPosted: Mon Jul 24, 2017 8:55 pm
Well, took pics today and they didn't turn out very good, will try again tomorrow.
PostPosted: Sun Aug 13, 2017 5:15 am
i painted my bed black
PostPosted: Tue Aug 15, 2017 1:09 pm
I am in the progress of rebuiding my brakes.I wait for all the wheel cylinders to arrive,i got a new master cylinder and new shoes.
Does anybody knows the bleeding procedure?The master cylinder has 2 reservoirs one for the rear and one for the front.
Do i first bleed the rear and then the fronts?Or it doesn't matter?
I forgot to mention my luv has drums at the front.
PostPosted: Tue Aug 15, 2017 9:03 pm
Start with the back brake furthest from the reservoir, do the other back brake second, do the front brake furthest from reservoir third, finish up with the last one.
It probably doesn't really matter if you do the back first or second if you have 2 separate reservoirs, that's just a good habit to get into.
PostPosted: Tue Aug 15, 2017 10:39 pm
I've always bleed the furthest wheel cylinder 1st and work closer when bleeding brakes BUT for some reason the shop manual CONTRADICTS THAT
& tells you the correct sequence of bleeding is to start w/ the nearest to the master cylinder first then the next nearest & so on ....ALSO gives a warning to do so while the engine is running.....Here is a picture from my Series 6 Shop manual.
PostPosted: Fri Aug 18, 2017 2:44 pm
Thanks for the info guys.I guess will go the traditional way :D
One more question.How can i remove the dashboard?Is it glued on the metal under it?Does it need to get the windshield out.
PostPosted: Sun Aug 20, 2017 12:15 am
I've taken a couple off at yards I removed the parts off the dash and slowly pull it away where you can and use a putty knife separating foam from metal dash apart in the all openings, all around slowly working all over till ya get it free
PostPosted: Tue Sep 05, 2017 11:22 am
Still waiting for the wheel cylinders to come.It s been over a month now :( :(
I removed the dash and repaired it my self as good as i could cause no shop here said could fix it.
Made a pair of aluminum door panels.
Took the heater core out and send it for repair.
PostPosted: Tue Sep 12, 2017 10:14 am
I got tired of waiting for the wheel cylinders to arrive.I believe the parcel is lost.So i am thinking of going for brake discs swap.
I found a complete from kb26.Do you know if i can fit them on my luv?Is the spindle the same?
PostPosted: Tue Sep 12, 2017 12:06 pm
Assuming there are no bizarre differences between the kb and the luv, this article should be helpful. http://www.luvtruck.com/Information/Brake_swap.htm
PostPosted: Thu Sep 14, 2017 5:53 pm
i have red that article a millions time :D
i asked from the seller a rear view pic of the brake discs spindles.
Whar do you think?
PostPosted: Tue Sep 19, 2017 11:46 am
I am trying to figure out a way for the front disc swap.Do you know if i can use the front ends of a 4x4 luv?
PostPosted: Tue Sep 19, 2017 5:22 pm
What isn't working out on those?
PostPosted: Wed Sep 20, 2017 4:14 am
I can t find any discs from a 2wd to swap my brakes so i was thinking about the 4x4.
Last night i was searching on some very old posts here and a guy here used the brakes from a pup on his luv so i think that is what i am gonna do.
Only difference is that the the mount for the tie rod is a little higher.
PostPosted: Wed Sep 20, 2017 8:08 pm
I'd get in touch with oldestisuzuist. In my opinion, he is possibly the most knowledgeable person here (and on isuzupup.com) about what crosses over between what we call the "first generation" and "second generation" LUVs.
