It is currently Fri May 22, 2026 4:35 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed Mar 29, 2017 6:09 am
More pics...
My luv project
https://youtu.be/wd5eCjrNL6U
PostPosted: Wed Mar 29, 2017 6:11 am
Next step is make all brake lines from the master cylinder to all wheels. Im using a brake line kit drom Ebay that comes with 25 feet of brake tubing, fittings, flare tool and bending tool. After that i will imstall an universal.hotrod 18 circuit wire harness...
My luv project
PostPosted: Sun Apr 23, 2017 5:40 am
Engine is in
My luv project
PostPosted: Sun Apr 23, 2017 5:42 am
One more pic. Next im orserimg a fully adjustable upper arms
My luv project
PostPosted: Sun Apr 23, 2017 10:59 am
Ordering from where? I have had more than a few bad experiences trying to get them...
PostPosted: Sun Apr 23, 2017 12:03 pm
SPC upper control arms. They have different sizes and ball joint angles.
My luv project
PostPosted: Sun Apr 23, 2017 2:09 pm
Are they LUV specific or generic? The LUV bolt spacing for the mounting is an odd size. (You can always weld a new attachment point).
PostPosted: Sun Apr 23, 2017 5:43 pm
Generics, they have a 5 inch shaft control arms amd can be ordered in different ball joint angle plates, im gonna try these arms in my luv, i hope they bolt to the existing holes.
My luv project
PostPosted: Sun Apr 23, 2017 7:40 pm
Pretty sure they won't... On mine, I bought a set of the generic adjustables and sectioned the cross shaft to fit though...
Took this much out between the bolt holes...
PostPosted: Mon Apr 24, 2017 6:51 am
What brand are those? Did u have any problems with the aligment?
My luv project
PostPosted: Mon Apr 24, 2017 9:16 am
Speedway motors sells them. I am not running stock spindles, so not sure how they work with stock stuff...
PostPosted: Mon Apr 24, 2017 8:07 pm
Endless project
My luv project
PostPosted: Wed May 03, 2017 9:17 pm
Chrome water pump pulleys, front and rear brake hoses arrived today, brake lines are installed and ready. Battery was relocated on the frame under the bed by the passenger side. Also i installed new 3/8 fuel hoses.
My luv project
PostPosted: Wed May 03, 2017 9:18 pm
More pics. The kit i got from powerbyace.com works pretty good.
My luv project
PostPosted: Wed May 03, 2017 9:20 pm
Everything fits perfect. Ill try ti find a toyota hilux from bumper and modify it to fit the luv
My luv project
PostPosted: Wed May 03, 2017 9:27 pm
I adding aftermarket gauges to the stock cluster for a oem look. I ordered a fuel gauge kit that comes with gauge and fuel level. In the stock temp gauge im gonna install a 3 3/8 tachometer. I found a 85mm gps speedometer in ebay that will go im the middle stock gauge. Im gonna go.dashless in my truck, i already have one layer of fiberglass on top of the dash frame. In the next couple days ill apply another layer of fiberglass and smooth it out with body filler. Also i installed a 3 gauge set under the dash right in the bottom of the cigarrette light tray (oil press, water temp, volts?
My luv project
The battery
My luv project
PostPosted: Sun May 21, 2017 9:30 am
This is an update of my project. I went dashless, fiberglass and body filler did the job, not perfect but lo9ks nice
My luv project
PostPosted: Sun May 21, 2017 9:32 am
Dashless pics
My luv project
PostPosted: Sun May 21, 2017 9:33 am
More pics
My luv project
