It is currently Thu Dec 18, 2025 1:52 pm
 Post subject: ford
PostPosted: Thu Aug 14, 2003 3:51 pm
anyone ever hear of a ford V-6 being put into a luv?
PostPosted: Fri Aug 15, 2003 6:06 am
yes advance adapters used to make a kit for the capri V6 to fit.
im not sure what size engine that is. it has been a while since I have seen the info on that.
03Cobra
PostPosted: Fri Aug 15, 2003 11:05 pm
Japanese Redneck
Capri V6 used to be almost as common as the buick 231 swap in mini trucks. I liked that motor.
PostPosted: Sat Aug 16, 2003 4:51 pm
My folks used to have a friend that owned a little Capri I thought it was the coolest little car he had these low profile tires on it and he had it all set up for racing it was a blast.
my two pennines
Later
Husker
PostPosted: Sun Aug 17, 2003 12:17 pm
Contact Tim Beezley. You can find his info in the projects section of the gallery. His truck had a V-6 Ford motor before he upgraded to a SB setup.
PostPosted: Thu Dec 18, 2003 1:18 am
yeah, im the guy that had the v6 ford, it was in there when i bought it, i might still have the motor mounts running around if ya want me to look for em. it was a 3.0 v6 AOD outta an 89 ford aerostar van, didnt run that great, but the tranny was also goin out, wouldnt even powerstall on water :roll:
just your average bagged v8 mini truck
PostPosted: Sun Dec 21, 2003 12:19 pm
wonder if a 2.8 out of a pre-86 ranger would work. they had a horrid mess of computer controlled carb junk, but you could yank all that and slap a weber 40 on and call it good. only problem i've heard of being real common with those is that the valve seals wear out and smoke, but easy to fix
i think most trannies that would fit a windsor smallblock bolt up to this motor
PostPosted: Sat Jan 03, 2004 2:41 am
you prolly already did something, but, i just thought id let you know that the heads have a tendencie to crack,and that the ydont even run that great to begine with.
PostPosted: Tue Jan 06, 2004 2:06 am
Ive heard of alot of motor swoppin but I dont think I have ever heard of a ford motor in a luv. Kinda gives me the shakes, but if it works and you can still smoke the tires then I guess it couldnt be all that bad. :)
PostPosted: Wed Jan 07, 2004 6:36 pm
I've seen a 351 ford in a luv once, but never a V6. Also knew someone with a Dodge 318 in a luv once upon a time. With enough fabrication anything is possible, and V6s tend to take a little less banging on the firewall to fit. Now if you really just want to be different, slap a Wankle in there. Ford (well, Mazda) did a rotary in Couriers back in the day. I imagine if one could get their hands on a 4 rotor imported motor it could be a very interesting swap. Rear end gearing would be fun to work out, but anything is possible.
PostPosted: Wed Jan 07, 2004 7:24 pm
OG Lifer
The old saying goes, "put a chevy motor in a ford to make it go fast". Do what you want, but I would stick close to home. Chevy in a chevy if it were me.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Wed Jan 07, 2004 9:49 pm
for info on those rotary pickups, go to http://www.mazdarepu.com
it's a rotary pickup fansite, there's some guys who are really knowledgeable on those cool trucks. they're easy to spot, they look like an old courier with the words "ROTARY POWER" on the back.
however, i don't think a rotary really belongs in a truck...they kind of lack torque. definitely has cool factor though
PostPosted: Sat Jan 10, 2004 10:29 pm
if u want more power on an engine swap, my freind had a rodeo 6 cyl that he put in a '90 s10 that was 4cyl (i nkow its an s10 @_@ but still) and it fit tight. but troopers are a good choice too
PostPosted: Sun Jan 11, 2004 11:33 am
sounds like it could have been the piece of junk gm 2.8 v6...then again it might not have. i know that motor was in isuzus in the late 80s-early 90s though
PostPosted: Fri Jan 16, 2004 10:15 pm
WELL LOOKIE HERE MINE HAS A FORD MOTOR IN IT 8O
http://WWW.QUINNSRACING.CJB.NET
PostPosted: Sat Jan 17, 2004 1:05 am
BLASPHEMY!!! I swear ..... "ford motor" and "in a luv" shouldnt ever be in the same sentance....unless its saying "a ford motor shall never be installed in a luv"
PostPosted: Sun Jan 18, 2004 12:35 am
LOL THATS FUNNY :lol: ILL B DANGED IF THATS THE ONLY WAY I COULD GET IT TO GO FAST I TRYED THAT CHEVY THING DIDNT WORK SO GOOD LOL
PostPosted: Sun Jan 18, 2004 10:58 am
OG Lifer
Caps locks sucks :wink:
My ford isn't slow either
PostPosted: Sun Jan 18, 2004 4:18 pm
but grimace....its still a ford! lol
That quinn dude deserves to be dragged out into the street and shot :!: how dare he stick a ford badge on a luv!
PostPosted: Sun Jan 18, 2004 5:02 pm
hey, it is an isuzu after all. i think that kind of voids the "chevy only" thing :P
you guys think it's gonna degrade my toyota when i put a gm 4.3 in it?
