It is currently Sun Jun 07, 2026 8:33 pm
 Post subject: Fan clutch
PostPosted: Sat Jan 17, 2004 1:14 am
Does anybodys fan for there radiater have a thermal fan clutch on it or is it just hooked up straight to the water pump. Because mine is just hooked straight up to the pump. Thanks Shane
PostPosted: Sat Jan 17, 2004 2:50 am
mine is bolted right up too. My 78 was bolted directly up and my buddies 79 was that way as well.
PostPosted: Sat Jan 17, 2004 3:00 am
my 280z has a thermal fan clutch so I wasnt sure, thanks man
PostPosted: Sat Jan 17, 2004 3:05 am
you have a Z huh? Those are sweet cars, my buddy has a 78 280 and its awsome.
PostPosted: Sat Jan 17, 2004 3:50 am
about the fan, from what ive seen all fans that bolt to the water pump dont have a clutch, only thermo fans do
PostPosted: Sat Jan 17, 2004 10:19 am
Mine is a 1978 280z is his the fuel injected kind
PostPosted: Sat Jan 17, 2004 1:45 pm
the 4 blade fans on the luvs don't have a clutch, the 6 blade fans off the later pups have a clutch.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
PostPosted: Sat Jan 17, 2004 2:53 pm
OG Lifer
79 and I have a clutch on mine.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Sat Jan 17, 2004 4:22 pm
Hey grimace do you have the 6 blade or 4 blade fan and did you put the fan clutch on yourself or did it come with it. Thanks
PostPosted: Sat Jan 17, 2004 4:31 pm
OG Lifer
6 blade plastic fan. The clutch I got from o-reillys and had to do away with an adapter plate that was on my fan.
PostPosted: Sat Jan 17, 2004 9:55 pm
yeah my buddies Z is a fuel injected one. It dosnt run so i towed it for him whith my luv, he got it for $250 8O . We were kinda poking around at it this summer but didnt realy get anywhere. I am lost when it comes to FI, though now that i have been through my 90 troopers motor i have some understanding of it :)
Oh is the FI on the Z mechanical or computer?
PostPosted: Sat Jan 17, 2004 10:29 pm
Its computer it has a fuel injection brain under the drivers side kick panel, if it isnt running the first thing you might want to check is if the distributer cap is cracked, I guess there notorious for that. It costs like $7.00
PostPosted: Sat Jan 17, 2004 10:38 pm
we have done a full tune up, replaced all the vac lines and pulled the valve cover to make shure all the valves were working. My buddy dosnt have the money to work on it right now(that and its too cold to work on anything). Well probly rebuild it this spring.
PostPosted: Mon Jan 19, 2004 6:58 am
All of them that I have seen have been bolted on. That is not to say that you couldn't take that off and put on a thermo unit. I think it might even give you a little better cooiling performance.
PostPosted: Mon Jan 19, 2004 12:50 pm
I see no words.....all I see is an avatar....... 8O
03Cobra
PostPosted: Mon Jan 19, 2004 1:16 pm
isnt it great! i didnt like Yoda much :? :lol:
PostPosted: Mon Jan 19, 2004 1:53 pm
It would look better with real hood ornamants.
PostPosted: Wed Jan 21, 2004 3:50 pm
yoda?
PostPosted: Wed Jan 21, 2004 6:59 pm
hood ornamants?
PostPosted: Thu Jan 22, 2004 1:22 am
OG Lifer
Nekkid?
Users browsing this forum: No registered users and 67 guests
