It is currently Sun Jun 07, 2026 12:43 am
 Post subject: Generator light on...
PostPosted: Mon Sep 12, 2016 4:40 pm
So, driving down the road and my charging light goes on.
Turn around and head home worried that my fuel pump will die and I'll be stuck. Make it home.
Did the Fuse Box Fix years back so figured that's not it.
Replace fuse for the regulator. Nope.
Switch the Alternator. (I have a parts truck) Nope.
Switch the Regulator. Nope.
Unscrew the mounting screws on the Fuse Box. Pull and replace all the connectors. Re mount fuse box.
Light is now off.
Hope it helps the next guy.
PostPosted: Sun Sep 25, 2016 5:28 pm
Fixx'D it...Good 8) SOUNDS LIKE maybe you had a loose connection at the fuse box a lot of problems start right there
PostPosted: Sun Sep 25, 2016 5:37 pm
I second this. I used to get issues like this on hotter days especially.
PostPosted: Sun Sep 03, 2017 8:49 pm
Thank you!!!! Just about to give this a shot.
I've replaced the alternator twice. (Got sent a bad one).
Regulator already looks new with fresh wiring (previous owner must've replaced)
My next step is what you posted. Wish me luck.
79 4x4 Mikado
