It is currently Sun Jun 07, 2026 12:43 am
PostPosted: Sun Jul 03, 2016 11:26 am
I just bought a 19xapprox 19 1/2 in radiator that is for a scion xb. The radiator mounts are 18 3/4 in wide. I was wondering if anyone knew a way to make it fit without cutting up the mounts. I would like to be able to revert back to a stock rad if I want to
Yellow 74 LUV. Factory a/c
White 79 LUV. Factory a/c
Tucson, AZ
PostPosted: Sun Jul 03, 2016 11:27 am
Here are some pictures I took
Tucson, AZ
PostPosted: Sun Jul 03, 2016 12:08 pm
Another picture
Tucson, AZ
PostPosted: Sun Jul 03, 2016 12:10 pm
Other side
Tucson, AZ
PostPosted: Sun Jul 03, 2016 12:21 pm
i cut mine out removed a strip of material and rewelded them with a wider opening. But you cant go back from that
PostPosted: Sun Jul 03, 2016 12:46 pm
As I said before, I would like to widen them both maybe 1/2 in. so that way I could be able to revert back to stock if I chose to do so. I was thinking about bending them out with a hammer but I don't know if it would widen the opening enough to slide the rad in.
Tucson, AZ
PostPosted: Sun Jul 03, 2016 12:57 pm
lovefortheluv If you could send me a picture of your setup that'd be great
Tucson, AZ
PostPosted: Sun Jul 03, 2016 5:30 pm
The beauty of metal and welding is that nothing is irreversible.
