It is currently Sun Jun 07, 2026 9:49 pm
 Post subject: front axle
PostPosted: Wed Jan 14, 2004 5:34 pm
i have a '80 luv 4WD, and i was replacing the cv joints and the axle spline. the front spline fell off at the bushing but i dont know how to get the longer spline out of the front axle. is there a pin in the front differential or what? bare with me i am new at this.
PostPosted: Thu Jan 15, 2004 12:30 am
OG Lifer
There are four bolts around a large steel cylinder. Take those four bolts out, and the rest of the axle will come out too.
This will also loosen the front end housing so be careful and support it with a jack. Hope this helps :wink:
Oh, and Welcome to the site :D
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Thu Jan 15, 2004 12:45 am
on top of wht grimmace said you will have to unbolt that sides braket fron the frame (there are 2bolts on the top of the braket). The braket will come off whith the axle. There will be a bearing a seal and 2c-clips you will have to transfer over to the new axle. Take your time and make shure you have everything put on the right way.
PostPosted: Thu Jan 15, 2004 10:15 pm
there is a white plastic plug on top of the axle tubing. what is that for?
PostPosted: Thu Jan 15, 2004 10:46 pm
that is a breather, the axle has breathe. good luck on finding those outer bearings in the axle, i looked all over with no luck.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
Users browsing this forum: Google [Bot] and 63 guests
