It is currently Sun Jun 07, 2026 12:49 am
 Post subject: Shifter boot
PostPosted: Thu Mar 24, 2016 12:34 pm
I need a new shifter boot what is the best one to go with for a 73 LUV ?????
 Post subject: Re: Shifter boot
PostPosted: Fri Mar 25, 2016 5:19 pm
ok guys and ladies I'm looking at the Mr Gasket 1651 shifter boot but the info on it says its 5 1/2 in dia the opening on my luv is 4-4 1/2 will this work before I go buy it ?????
PostPosted: Fri Mar 25, 2016 6:10 pm
That looks like it would fit to me.
I went to the junk yard and pulled a leather shift boot off a BMW for mine that was under $10. I cut the bottom rubber ring off of the stock one and pulled the leather one through the hole.
PostPosted: Mon Apr 04, 2016 1:08 pm
Did the Mr Gasket work?
1979 Base 4x4
PostPosted: Mon Apr 04, 2016 2:35 pm
Just got it today and the weather doesn't know what it wants to do so hopefully to get to it soon.
I will post pics when I get it done
PostPosted: Fri Jun 17, 2016 1:03 pm
Just wanted to ask if you had installed the shifter boot kit, and how'd it go????
PostPosted: Sat Jun 18, 2016 2:39 pm
working on putting the vinyl floor in then the boot will go in but it looks like it will be fine.
I will post pics after I get it all done.
PostPosted: Sat Jun 18, 2016 6:16 pm
This is the one I made from a BMW E-brake boot and the base of a stock rubber boot. My trans has a 2" thick piece of foam that fits over the shift lever and seals off the cab from the trans.
PostPosted: Sun Jul 03, 2016 1:18 pm
I broke 2 drill bits trying to drill the back 2 holes to mount the chrome ring
PostPosted: Sun Jul 03, 2016 1:24 pm
Looks real good 8)
PostPosted: Tue Aug 30, 2016 10:51 am
Where did you get your vinyl floor? Looks real nice.
PostPosted: Tue Aug 30, 2016 5:28 pm
http://www.automotiveinteriors.com
is where I got the vinyl floor it wasn't 100 fit had to trim and fit and the seat hides a lot.
I actually removed the seat and then put the floor in.
Users browsing this forum: No registered users and 66 guests
