It is currently Sun Jun 07, 2026 8:02 am
 Post subject: 1972 luv engine issues
PostPosted: Sat Mar 12, 2016 11:51 pm
OK so this 1972 chevy luv is giving me hell. I can get it to run for about 30seconds and then it dies. Bought because the engine had been rebuilt but it was giving the original owner the same issue. Just hoping someone could help. Have it at the mechanics garage and even they can't figure it out. Any ideas will be appreciated.
PostPosted: Sun Mar 13, 2016 12:31 pm
Check the voltage to the fuel pump while cranking and then running.
The fuel pump gets power two different ways. It'll get power while the key is in the crank position and then it gets power from the alternator once the key is in the on position.
The bowl on the carb could be filling up while you crank it, and then the pump stops and it runs off the fuel in the bowl for a few seconds.
PostPosted: Sun Mar 13, 2016 12:39 pm
I'm gonna forward this to my mechanic thank you I'll let you know how it goes
PostPosted: Mon Mar 14, 2016 12:27 am
That is correct if it has been converted to an electric fuel pump. 1972 models had a mechanical fuel pump stock.
PostPosted: Tue Mar 15, 2016 7:30 pm
well the problem we have is no timing marks on camshaft to line up on thrust plate.
Sent screenshot to the mech he replied with the above
PostPosted: Wed Mar 16, 2016 4:02 pm
Get your mechanic a series 1 (1972) LUV manual.
Users browsing this forum: Baidu [Spider], Bing [Bot] and 14 guests
