It is currently Fri Jun 26, 2026 11:34 pm
PostPosted: Tue Mar 08, 2016 12:17 am
Good ole sun dried parts got some black paint. I wire wheeled the bare rusted front frame and sprayed some paint to help prevent from rusting up too soon... I Started pulling them old cut hose off in prep for installing the motor
PostPosted: Tue Mar 08, 2016 12:19 am
got the engine back in & it's starting to look like were making progress :D
PostPosted: Tue Mar 08, 2016 12:25 am
step by step getting there intake cleaned up & back in hoses all hoked up underneath & got the carburetor back in
PostPosted: Tue Mar 08, 2016 12:31 am
getting closer the wires are getting hooked up, battery is back in & almost time to get her to run :D
PostPosted: Sat Mar 12, 2016 8:53 pm
looks nice has it started yet?
PostPosted: Thu Mar 24, 2016 12:28 am
Thanks its been quite a project & Yes I've been driving it around ...just slow to sort thru pics & post.
PostPosted: Thu Mar 24, 2016 7:23 am
Damn seems like you did that pretty fast. Looks good.
PostPosted: Thu Mar 24, 2016 12:43 pm
Juan, I found this truck in 09 & it was down 2 yrs after i got it going again as the 5spd trans i had ran dry and made terrible noises on the freeway and hr away from home in traffic... in fact i was
coming home from your area when it happened...lol just came down over that hill w/ fans and by the Honda dealer ship on 580
AS I BELIEVE I RAN GEAR OIL IN THE TRANS :oops: it was dry as a bone inside ...I WON'T do that again... :esad
slowing changed out front end parts working on the wore out stuff making it solid before making her PRETTY
I rolled down to San Jose PnP yesterday in it. It ran fine stayed cool even in traffic coming home, I think that the furthest I've taken her since the new trans.. been keeping her kinda close to home
Hows your coming along ?.....I'm ready to roll back that way & see what your up to on yours if your up for it. What parts you looking for on yours these days ?
PostPosted: Thu Mar 24, 2016 6:17 pm
You went to check out that luv at the pnp huh lol. I need the seat belts. I lost my key yes I only had one key so now I'm waiting for an ignition switch to come in. My girl said it came in today I'm till at work. So hopefully this weekend she's running again.
PostPosted: Thu Mar 24, 2016 7:54 pm
Yep drove out there w/ no pics to know what to expect ...Yea .. lol headed out at 9 am left theer at 330 home by 6:15 good ol bay area :)
I was looking for front end parts for a friend's truck & I still need a smog pump...my bearings are fried and squealing so i pulled the belt for now ...& I believe after this trip (4hrs) gas mileage has dropped.
Here is pics of what i found down there... front end crunched pretty good. someone must have made it out to it before me as a tail light was hanging, couple parts inside was missing, the ignition was gone seat belt were still there but not sure of condition...wish i had known or have asked & snagged them for ya ..... :signoops
hood hinges were busted so you could only peek in till i pulled the hood latch off to see inside.
The carb & motor was complete & looked fine The smog pump was tuff to get out & when i did, realized it had a bent shaft so no sale .. The dash had a dash cap on it...
They charged me 12$ for it :D ... can't beat that ...LUV IT ! got a few spare parts.
PostPosted: Sun Mar 27, 2016 8:38 pm
OK back to sharing more pic of this rescue cleaned out some stuff in the cab floor boards didn't get miss treated to much their still solid there was lots of dirt that settle in the dash area blew it out and wipe what i could out connecting didn't look too bad cleaned a few
PostPosted: Sun Mar 27, 2016 8:46 pm
slowly starting to look like a truck again w/ the fenders off i wire wheeled what look rusted and gave it a quick coat of flat black to help w/ rust down the road
so I started getting this label so i can dial in my brain at what i'm looking at
PostPosted: Sun Mar 27, 2016 8:49 pm
better view labeling ~ to share w/ others
PostPosted: Sun Mar 27, 2016 8:58 pm
ok close up of a stock carb all cleaned up ..
This carb has been on all 3 of my LUVS :D hasn't given much problem since i bought it back in the late 80's
This was the dash i pulled out of her typical cracks and lower 1/2 seems fine ...so many reworking it down the road to share w/
other as i have found a better one and save d several more to rework
PostPosted: Sun Mar 27, 2016 9:07 pm
Here are the 3 relays under that metal box on the pass fender....They still had numbers on them so i noting those just in case their needed.
not sure on the earlier years 72-74 but My truck is a 77 has 3 (I believe 75-77 are the same w/ 3 ...but not so sure on 78-79 )
I have notice the 80 model only had 2 relays & wiring harness is also different so heads up
Last edited by 3rdLuvNext2a66MALIBU on Sun Mar 27, 2016 9:44 pm, edited 1 time in total.
PostPosted: Sun Mar 27, 2016 9:23 pm
When i got to checking out the back wires i notice the little box for trailer lights i guess but
more interesting I wanted to know what the 778 that is stamped in this round plug located on the back of the bed....What do you think ?...
Maybe the year of making the bed since it was added on when it came to the states ??
I heard step side beds came out in 78 and this is on a 77 Truck
......... ANYONE ???
PostPosted: Sun Mar 27, 2016 9:35 pm
At this point the distributor was causing me problems & my spare was broke too So i got to learn how to take one all apart :lol:
my motto is if it broke i can't make it worse so why not pull it apart you already have to replace it so what the heck...LEARN
PostPosted: Sun Mar 27, 2016 9:42 pm
Next a friend was over so i pulled off the bed while i had help & found some rusting holes in the front of the bed...more later :esmile
PostPosted: Mon Mar 28, 2016 6:52 am
Damn dude u have done a shit load of work to this already. I didn't know ur truck has all those relays. I don't think my 74 has one? Well not that I know of lol. Looking good tho. What is that in the back? A big greenhouse? ?
PostPosted: Mon Mar 28, 2016 10:23 am
Thanks its been quite the project... and still, a ways to go so no tin cover on the pass fender & no relays on earlier yrs hummm...Well your lucky :lol: ...
I know there trouble when they go out played "WHICH ONE IS WHICH "so i pull & save the ones i come across
A friend of mine let me use this shed to work on my 66 chevelle & its over by the Richmond dumps.
Color spot and Orchids are grown near by in these green houses
