It is currently Sun Jun 07, 2026 7:09 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Tue Jan 13, 2004 6:28 pm
is the knocking noise coming from the engine or transmission. if its from the engine, i wouldn't be driving it unless you have a spare block. it would be bad for it to blow and take out the side of your block.
PostPosted: Tue Jan 13, 2004 8:23 pm
well 800xl i went to have oil changed in tranny and motor and the tranny doesnt really make sound much its hard to hear over the weber carb
PostPosted: Tue Jan 13, 2004 8:26 pm
and it is the tranny when i push in clutch the noise will stop but since oil change i got today it might have cleared it up but i notice now my clutch is in need of replacing after a lot of burnouts and stuff oops
PostPosted: Wed Jan 14, 2004 11:02 am
It sounds like a chirp? It would seem like it is the clutch disk fingers wearing off. My 81 did it.
PostPosted: Wed Jan 14, 2004 7:00 pm
i think my tranny is fine now i think it was jus low on oil i cant really hear the noise but ya clutch dad says needs adjusted
PostPosted: Thu Jan 15, 2004 8:44 pm
That should not be that hard. Hope it works out!
PostPosted: Fri Jan 16, 2004 7:04 pm
well didnt adjust it and i just started hearing the same noise again in my transmission it is definetly the bearings it needs to be rebuilt so soon i will so it still is a problem well i m jus gonna drive it for a while i m too tired to work on it right now thanks guys thanks for listening
PostPosted: Fri Jan 16, 2004 11:22 pm
No problem. We do expect you to listen when we smash our thumb with the big hammer 8-) :!:
