It is currently Thu Jun 18, 2026 1:16 pm
Post new topic Reply to topic  [ 202 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11  Next
PostPosted: Wed Nov 11, 2015 12:29 pm
Thanks guys. This dash repair is a PITA...
Haven't spent much time on it. I got another resto project for a customer I am working on in what little spare time I have, so it is on the back burner mostly. I probably am around halfway through with the dash. I need to finish it and the trans tunnel, install the shifter/console, finish up a crossmember I am modding, and wire it. I have a timeline goal for completely finishing the truck but I hate to post it as chit usually comes up...
PostPosted: Sun Nov 15, 2015 8:19 pm
One step back... Two steps forward...
Worked on the crossmember mod...
And the rest of the pics suck, but I got it all roughed in, and the center notched to (hopefully) clear the driveshaft at travel...
I also finished the trans tunnel, will start on the shifter mount next...
The bad was the shop cat knocked my dash pad over and it is wacked, I can continue on with what I was doing to it, but I am gonna take the lazy way and just install my spare dash and new dash cap...
PostPosted: Mon Nov 16, 2015 7:08 am
Ben's old 76 had cut outs like these for the exhaust. nice! 8)
PostPosted: Tue Nov 17, 2015 1:19 am
Thanks...
Sooo... much for planning, lol... I bought a B&M quicksilver shifter, then decided to get the camaro console. Well the console shifter they make for that has a different base. I can make it work... but... The console is a tight fit between the seats. I will not be using the 1967 Chevelle buckets in it now that I have a 1967 Chevellle, so I just scored a different set off Feebay that I hope are narrower. I only need about half an inch...
I screwed the shifter base down to work with the console if it will fit, and like the position, so it will stay. If the console don't work, the place I cut out of the hump for the console to clear looks like a nifty place to mount the MSD and the trans controller, so no biggie...
PostPosted: Sun Nov 22, 2015 12:38 am
Pic of said removed hump...
PostPosted: Thu Nov 26, 2015 9:52 pm
My seats finally arrived. They are narrower, YAY!
However, the item was not exactly as described...
The driver seat frame is toast...
I will not use the frame, but to do my pre fitting, I welded it up, scabbing in what was missing...
Got the seat back together...
And the console will fit between them...
PostPosted: Fri Nov 27, 2015 7:01 pm
I managed to get most of the spare dash installed and the cap put on that...
PostPosted: Fri Nov 27, 2015 7:46 pm
So 65-66 mustang seats with 67-69 Camaro console . Looking good .
PostPosted: Fri Nov 27, 2015 7:59 pm
Yes, they are, and thanks...
PostPosted: Sun Nov 29, 2015 9:34 pm
Another picless post, but wiring is wiring, lol... I started sorting the wiring, and wiring in my 6 gauge digital panel. Of course the sneders for them need some adapters to fit my engine... I did get the Spectre throttle cable trimmed and installed...
PostPosted: Sun Dec 13, 2015 9:25 pm
Let's see...
1. Got the radiator installed with floating mounts and got the upper and lower hoses on, had to shop for some I could cut down...
2. Mounted the heater control valve in a convenient spot, modified a cable to fit, and plumbed the heater hoses, except for one, ran out of hose...
3. Fabbed a bolt on bracket to add the tps cable to the throttle bracket, used the mount for it to help hold the throttle cable in place...
4. Installed and wired the TPS adapter. This is for the trans controller...
5. Spent a LOT of time trying to get electric fan configured for a puller, ended up not being able to, reinstalled a flex fan (no pusher, I want to put AC in it).
6. Mounted the Pro Coil and wired up the cap after I finally found it and put it on...
7. Mounted the Digital 6 box.
8. Put some jets in the nitrous lines so they would seal off...
9. Rechecked/tightened all the fuel connections...
10. Rechecked/tightened all the brake connections...
11. Installed the oil and temp sensors...
To be done
1. Need to source a ball for the carb to connect the tps cable to.
2. Short section of heater hose.
3. Need some water pump studs for the fan...
4. Drill a 1/8 NPT hole in the filler neck of the radiator to relocate overflow barb.
5. Install the catch can I just ordered when it comes in...
6. Finish the shifter install underneath the truck...
7. Mucho wiring... The Digital 6, the digital gauges, the NOS, the rest of the connections for the trans controller, and then any body wiring I lack...
8. Battery,fluid top off, and hope...
PostPosted: Fri Dec 18, 2015 3:53 pm
Im going to do the same thing up front where the T Bars used to be.going to run the exhaust through there to keep it higher that the bottom of the frame
PostPosted: Sat Dec 19, 2015 9:23 pm
1. Need to source a ball for the carb to connect the tps cable to. DONE
2. Short section of heater hose. DONE
3. Need some water pump studs for the fan... DONE
4. Drill a 1/8 NPT hole in the filler neck of the radiator to relocate overflow barb. DONE, decided not to do it, lol...
5. Install the catch can I just ordered when it comes in... DONE
6. Finish the shifter install underneath the truck... DONE
9.Install the trans cooler... Partially done, I have it mounted, just have to do a couple of bell flares and install the hoses... DONE
PostPosted: Sat Dec 19, 2015 9:31 pm
Oh man... you're close... Nice
PostPosted: Thu Dec 24, 2015 6:43 pm
Got the front shocks earlier this week. Today I had a few minutes and pretty much have the MSD wired. Just have to find the switch wire for it. I also decided to double up the grounds so I looked through the stash and got all of the stuff for that. Just got to crimp on an end and bolt it all up...
PostPosted: Sun Dec 27, 2015 7:36 pm
I finished up the trans controller wiring today, just have to connect it to the ignition run circuit. I fabbed a mount for the touchscreen and installed it, and hid the wiring for it all. PITA...
PostPosted: Sat Feb 20, 2016 8:11 pm
And I got some time to fool with it today, last update from 12-27-15 was the last time I touched it... I got all the wiring done (I think) except for the hot wire to the cigarette lighter... I got the gauge panel finished up and installed, installed my steering wheel (not completely done, I have to get the horn stuff in it) and the radio installed...
PostPosted: Sat Feb 20, 2016 8:58 pm
Where's the new dash? :)
PostPosted: Sat Feb 20, 2016 10:16 pm
Looking good 8)
PostPosted: Sat Feb 20, 2016 10:21 pm
It is shipping via Unicorn...
Users browsing this forum: Google [Bot] and 34 guests
