It is currently Sun Mar 29, 2026 8:09 pm
 Post subject: Looking for Radiator!!!
PostPosted: Wed Oct 30, 2002 11:01 pm
Ok y'all I went to get parts from another guy and he hooked me up with everything I need to do my disc conversion> Thanks Jim :wink: Anyway I was driving home and I noticed that the temp gage was running a little hot..... just on the high side of normal Well I kept an eye on it the whole way home. Well I get home and back her into the parking spot and shut her down and get out to take a look. I noticed water just running out from the bottom of the radiator havent really looked at it yet I will pull it this weekend to see if it's salvagable if not I'm looking to see if any of you guys out there who have ditched the 4 banger still have a stock radiator laying around that you dont need!! 8) Well anyway If you guys would just shoot me a message or an email. Hope that maybe one of the guys from Washington might have one? Well I have rambled enough hope to hear from someone soon ! my poor baby needs LUV !!!! :lol:
PostPosted: Wed Oct 30, 2002 11:41 pm
check the bottom hose adapter on the radiater.when i finally got mine running again.the last and final thing i had to do is put the radiater hoses on when i noticed the adapter was cracked.i was pi**ed.not really a problem though.just take it out and weld it.don't have a welder like me.just buy a torch($15) and sauter it
PostPosted: Wed Oct 30, 2002 11:50 pm
Well when I first got it I found a spot by the lower neck where it was cracked and I soldered it but for som reason it looks like it's leaking from higher up and runnig down which is the reason I'm looking for another if possible if not I was wondering if anyone had any suggestions for a cheap swap, what might be an easy swap from what other vehicles other than a Luv?
PostPosted: Thu Oct 31, 2002 12:12 am
i don't know whats the stuff's called but it in a little canister.it's made strictly for sealing radiator leaks.it kinda looks like sand.check into the stuff before you buy a radiator.it really good stuff.i've used it on 3 of my past cars and after that,no leaks.
PostPosted: Thu Oct 31, 2002 7:24 am
I got a radiator. actually 2.
make me an offer plus shipping.
if you need pics let me know.
03Cobra
PostPosted: Thu Oct 31, 2002 8:45 am
n.a.p.a auto parts caries brand new modine radiators for luv trucks if your looking for a new one. just put one in my luv two weeks ago the cost for the radiator was 115.00. hope this helps
PostPosted: Thu Oct 31, 2002 8:47 am
the stuff the other guy was talking about is called stop leak its good stuff but if your not carefull it will stop up your water pump and your water ports going through your block and heads.
