It is currently Sun Jun 07, 2026 7:30 pm
 Post subject: timing help
PostPosted: Thu Nov 26, 2015 1:53 pm
help i have rebuilt my motor and cant get it back in time 1.8 1980 pics would help
 Post subject: Re: timing help
PostPosted: Thu Nov 26, 2015 2:47 pm
Have you been able to get it running at all yet?
Where are you located?
If you havent got it running are you sure all of the wires are on the right plug and the distributor isnt 180* off?
Good easy test. Switch the plug wires with the ones opposite of them I messed mine up and did it 180* off so swapping wires around put it in the right order
PostPosted: Thu Nov 26, 2015 4:21 pm
i got fire it back fires thru the carb i have a book but the wording confuses me and the pics dont help at all im also sure on when to set the valves so i was going to start all over and doit with out droping the pan or taking off the front cover south west mo (el dorado springs) and i read something about the oil pump being
part of the timing ?????
PostPosted: Thu Nov 26, 2015 4:47 pm
How are you wiring it? I think the firing order starts with 4...
PostPosted: Thu Nov 26, 2015 5:14 pm
The distributor is driven by the oil pump. You can change it without pulling it out.
Make sure your firing order is right and if it spits another fireball switch the wires for the ones 180* away so just straight across.. fire out the carb could be from the plugs firing while an intake valve is open..
PostPosted: Thu Nov 26, 2015 7:00 pm
ok i know the keyway on the crank is 12 oclock where is the tryangle at on the cam sprocket suposed to point
i dont have a thrust plate or double chains
PostPosted: Thu Nov 26, 2015 9:54 pm
Match mark on the chain & cam sprocket should be about 1-1/2 teeth to the left looking from across the radiator. The camshaft dowel through the cam gear(not the keyway) is straight up. If the crank keyway & the cam alignment dowel are both at 12 o'clock the crank and cam are at #4TDC & your distributor rotor should point to the #4 terminal in the cap. If something is different please explain what you have. All Isuzu 4 cylinder engines time at #4TDC, ALL the alignment marks will align ONLY at #4TDC, using #1 commonly gets timing 180 degrees out.
PostPosted: Fri Nov 27, 2015 8:56 pm
ok i will try that
PostPosted: Tue Dec 15, 2015 3:10 pm
it runs :lol:
PostPosted: Mon Dec 21, 2015 1:11 pm
8)
SO tell US (the 109 who viewed this is wondering).. =) .....What was it that you done to get it running ?
PostPosted: Mon Dec 21, 2015 7:35 pm
My guess from ready the posts is someone rebuilt the engine and timed the dizzy to No1 instead of no4. He had to move the wires around to get it going.
PostPosted: Tue Dec 22, 2015 5:53 am
well it looses oil presure when it gets warmed up but i have been driving it to work n back for 2 weeks while i work on a frame that isnt rusted in 2 going to get it ready then move my body over to a good frame :D :D :D :D 8)
