It is currently Fri Jul 03, 2026 5:00 pm
PostPosted: Sat Oct 17, 2015 1:07 pm
Hey,I'm cleaning up the stock intake in prep for the new Weber carb. I've removed the smog gear from the truck and filled the hole leading from the pipe that came from the exhaust manifold. Inside the intake, directly under the carb is a little "wing" looking tab,cast into the manifold,that seems to divert exhaust gas around the plenum chamber. Can I cut this "wing" off so that there are no obstructions inside the intake?
Thanks, Steve
PostPosted: Wed Oct 21, 2015 4:28 pm
got it figured out when I read the carb install paperwork. thanks
Users browsing this forum: Baidu [Spider] and 28 guests
