It is currently Sun Jun 07, 2026 12:26 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
 Post subject: i give up too
PostPosted: Sun Dec 21, 2003 8:11 pm
my luv has jus made me mad grrr well now the intake manifold has a pin hole in it and letn my water spray out doh then i listen to when my car is idling i hear this funny noise from tranny and my dad says its the input bearing or somthin and anyways i wanna trash the tranny any ways and put a 5spd in it and i got an extra manifold layin around so ill do that next weekend or sooner if anything else brakes i am goin to take a sledge hammer and beat it till it works again
PostPosted: Mon Dec 22, 2003 8:37 pm
A hammer will fix anything, or fix it to where you have to have another. :lol: :lol:
PostPosted: Mon Dec 22, 2003 9:50 pm
If it aint broke, fix it til it is
PostPosted: Tue Dec 23, 2003 12:31 am
Duct Tape!!!!!
Then Hammer!!!
more Duct Tape.....
:lol:
PostPosted: Fri Dec 26, 2003 10:35 pm
Don't forget the bailin' wire and bubble gum. :lol: :lol: :lol:
PostPosted: Mon Dec 29, 2003 12:01 am
the intake is fine their was jus a hole in a hose :oops: LOL but still got tranny issues grr
PostPosted: Fri Jan 02, 2004 1:58 pm
I had to replace a crush bearing cause it well, crushed. It took me a few days.
PostPosted: Sat Jan 03, 2004 8:26 pm
is their any place that sell remanufactured 4 spd stock transmissions/transfer case for the luv ?
PostPosted: Fri Jan 09, 2004 7:38 am
I have seen a few. I talk to the boyz at the local AAmoco Xmission and they tell me that you can get the rebuilts from a transmission reman in the area, or they can order it. But for the most part, I have not seen A LUV specialist.
You can spam: info@allisonparts.net and see if they have any in stock tho.
Or go to switchboard.com and look up one in your area. They can probably get it for you.
PostPosted: Sun Jan 11, 2004 8:15 pm
If tranny problems are that bad then cut out floor board and do the fred flinstone thing :D :D
PostPosted: Sun Jan 11, 2004 8:30 pm
Or put the "I would rather push a Chevy than Drive a Ford" hat on and start pushin'.
PostPosted: Sun Jan 11, 2004 8:52 pm
maybe it could be your throwout bearing on the clutch. if you only hear the noise when you put your foot on the clutch then its the throwout bearing. if it goes away when you put your foot on the clutch then its in the tranny. maybe you could get a part number off that bearing in the tranny and buy it at a bearing place, and just replace that one. it'd be alot cheaper than a rebuilt transmission. or search for a bearing kit for the luv transmission on the internet. i've never looked for it but there might be one out there.
PostPosted: Mon Jan 12, 2004 7:20 am
May be the crush collar as well. Or a crush bearing.
PostPosted: Mon Jan 12, 2004 7:31 am
My dads truck makes a whiney sound when you push the clutch in, the problem....Throwout bearing. Maybe yours is doing the same thing??? :?
PostPosted: Mon Jan 12, 2004 7:39 am
When I replaced mine, it worked ok, but then the whine from the rear transaxle was not bearable. So I took two or three shims out of it and it was OK.
PostPosted: Mon Jan 12, 2004 11:06 pm
well the noise goes away when i push in the clutch and it makes a sorta knocking sound and i ve been bein a lil easier on it jus incase it totally screws up but maybe i ll find a tranny through the site i dont have money now but 2 weeks will have some more i cant really tear it apart either cause its my only transportation
PostPosted: Tue Jan 13, 2004 1:08 am
a luv will go a long way on bad parts, i know... :oops:
PostPosted: Tue Jan 13, 2004 2:09 am
well i ll see how long i can go maybe till i get some cash
PostPosted: Tue Jan 13, 2004 2:10 am
It wouldn't hurt to check/change the tranny fluid. My 76 had enough of a tailshaft leak to drop the fluid level down to the point it would make some extra noises when it got low. If it is a transmission noise, it could be running low on oil. Noisy now, but gets expensive later if not topped off.
PostPosted: Tue Jan 13, 2004 10:02 am
hmmm i ll check 800xl
Users browsing this forum: Bing [Bot] and 25 guests
