It is currently Thu Dec 18, 2025 2:15 pm
 Post subject: Body work
PostPosted: Sun Jan 11, 2004 12:50 am
Hey guys, I'm planning on doing some bodywork on the LUV before she gets painted up. I took the radio antennea out and now theres a hole there. How do i go about covering this over?? Its about and 1 1/2" in diameter. I don't need the radio anyways...you can't hear it over the exhaust.... :lol:
PostPosted: Sun Jan 11, 2004 8:57 am
Im assuming you dont have a welder. You could take the fender off and lay some fiberglass matt over it and use body filler on the top side to smooth it. Or you could slightly tap the edges of the hole down and use the matt on the top side without taking the fender off.
PostPosted: Sun Jan 11, 2004 1:42 pm
Oh i got a welder, arc and mig....hmm i never thought of welding a piece in there :? I was thinking just using body filler and some fiberglass maybe or something. This welder idea has opened up a whole new train of thought! :P
PostPosted: Sun Jan 11, 2004 3:34 pm
Cool, do it right and weld it!!! Just be careful not to get it too hot! Very thin sheetmetal on these trucks and they warp very easy!! Good luck! 8)
PostPosted: Sun Jan 11, 2004 11:55 pm
when you weld it up, use tack welds and switch sides, from one side to the other, that way it wont over heat and warp. then when you go to fill it with body filler, take a 36 grit wheel for one of the big grinders, and grind teh whole area, that will make the bondo stick better. then use a file board and some 80 grit to get it even,then some 220 grit to smote out the sand scratches, then fill any major sand scratches with spot putty. you prolly already knew, but just in case you didnt.
PostPosted: Mon Jan 12, 2004 12:17 am
Excellent, thanks for the advice guys! :D Hopefully will get at it next week. 8)
PostPosted: Sun Jan 25, 2004 12:38 am
i hope your a good welder, i would have just stuck with the fiberglass n filler. thats what im doing on mine coz im putting the antena on the roof :lol:
