It is currently Thu Dec 18, 2025 6:40 am
 Post subject: New guy question here...
PostPosted: Mon Aug 03, 2015 7:55 am
I recently purchased a trailer someone made using a Luv bed and frame/axles... I am looking into putting real taillights like what were originally in the bed. What year is this bed so i know what taillights to get? Also, is there any market for the rear axle out of this? I am considering pulling it out and putting a trailer axle under it so it weighs less and pulls easier.
Any info is greatly appreciated. Thanks guys!!
PostPosted: Mon Aug 03, 2015 8:29 am
Welcome
Not sure of the exact year you have, but any taillights from 74-80 should work. 72 and 73 had them under the tailgate, and 81-82 was a different style altogether.
Someone may want the rear depending on the axle ratio. There's not a huge market for most though.
PostPosted: Mon Aug 03, 2015 8:35 am
drummerforhire wrote:
Welcome
Thanks for your reply, do you know if there is a way to easily remove the gears so it rolls easier?
PostPosted: Mon Aug 03, 2015 8:59 am
I do not. Maybe someone else can chime in.
If you determine the axle ratio is 3.73 or 3.42 (I think) that is a desirable ratio and it'll sell pretty quick. Are there any numbers stamped on the unit?
PostPosted: Mon Aug 03, 2015 2:03 pm
I'll crawl under there in the next day or two and look for markings.
PostPosted: Mon Aug 03, 2015 2:31 pm
I would highly suggest swapping in a trailer axle setup if you are looking for weight reduction.
You don't want to run that without the 3rd member in it for various reasons.
PostPosted: Mon Aug 03, 2015 6:10 pm
i have a pair of tai lights with the light buckets id sell for 50 plus shipping
There can always be more then 1 LUV in your life
PostPosted: Mon Aug 03, 2015 6:11 pm
if you pull the axle shafts and te carrier and remove the ring gear put it all back together it would be eiser to pull
PostPosted: Mon Aug 03, 2015 6:12 pm
i didnt finish that right lol leave out the ring gear on re-assembly
