It is currently Sun Jun 07, 2026 6:36 am
 Post subject: wheels
PostPosted: Tue Dec 23, 2003 3:21 pm
ok i know that this is under stock trucks but i was wondering if anyone knows if 14 inch 97 nissan pick up wheels will go right onto a luv of someone knows the would be great if you could tell me thanx :D
PostPosted: Tue Dec 23, 2003 4:27 pm
just measure the wheel studs to see if they have the same spread. If the wheels are slotted then they should fit.
PostPosted: Tue Dec 23, 2003 4:46 pm
better check the backspacing, if its too deep they wont fit!
PostPosted: Tue Dec 23, 2003 5:49 pm
stockl nissan toyota and some other 6 lug patterns will fit i know the dodge and all those 6 lug will not fit though but yes the nissan will fit. matt
PostPosted: Thu Dec 25, 2003 2:42 pm
take some measurements to be shure. They should slip on but measure em to make shure.
PostPosted: Fri Jan 02, 2004 1:54 pm
So the Nissan's do fit? I will have to check it owt.
PostPosted: Sat Jan 10, 2004 6:25 pm
I HAVE THE CHROME 6 LUG NISSAN PICKUP WHEELS WITH TRIANGLULER HOLES, THEY ARE 14 INCH. I HAVE MY TORSION BARS CRANKED ALL THE WAY UP AND THE UPPER CONTROL ARM RUB THE INSIDE OF THE WHEELS WHEN THE SUSPENSION FLEXES. THE END OF THE CONTROL ARM IS THE PART THAT HITS THE INSIDE OF THE WHEEL RIGHT AT THE LIP.
PostPosted: Sat Jan 10, 2004 9:05 pm
I think then they might not be the right thing unless you can modify the body a bit so they can fit. i did manage to pick up the rims that were on the 4x4's and put them on the truck.
They are alot beefier than I thought. Bit a nice addition anyway.
PostPosted: Sun Jan 11, 2004 10:01 am
OG Lifer
Hey colin turn the caps locks off dude.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Mon Jan 12, 2004 1:51 am
My parts truck came with late model Nissan rims on it.
They do seem to rub if you turn sharp though.
77 2wd - Back on the road
05 Ford Five Hundred
PostPosted: Mon Jan 12, 2004 3:16 am
then they are probly just a bit wider or dont have as much backspacing. Where do they rub, A-arms or the frame?
PostPosted: Mon Jan 12, 2004 7:33 am
If you want some cool Rims, look for the 4X4 Luv Mags. I have mine on the truck after priming and painting them. The only problem is that I painted the tires too.
Nothing a little Acetone won't take care of.
