It is currently Tue Oct 28, 2025 8:33 am
 Post subject: 79 not staying running
PostPosted: Wed Apr 08, 2015 11:33 pm
I have a 79 luv that will only stay running with the key in the start position. It happened all of a sudden. Thought it was the ignition switch so I replaced it and it's still doing the same thing. Please help
PostPosted: Thu Apr 09, 2015 6:12 pm
Check all your fuses and relays.
PostPosted: Thu Apr 09, 2015 6:42 pm
I did and they're all good. I'm stuck never seen this before
PostPosted: Fri Apr 10, 2015 12:41 am
You have a open/bad ignition resistor on the coil. This is used in the run posistion but is bypassed in the start position.
PostPosted: Fri Apr 10, 2015 9:47 am
I agree with the above post. Sounds like a bad ballast resistor. To test by pass it with a jumper wire.
PostPosted: Fri Apr 10, 2015 2:10 pm
That's exactly what it was I just want to say thank you I really appreciate your help
PostPosted: Fri Apr 10, 2015 2:38 pm
This has been coming up her and on Facebook often in the last few months. I recomend removing the ballast resistor and stock coil, replace it with a universal internal ballast coil.
