It is currently Sun Jun 07, 2026 3:26 am
 Post subject: ignition relay
PostPosted: Mon Mar 16, 2015 9:07 pm
So my truck was running fine the other day, now I'm getting no power to my hei. I have the stock relays and pretty sure the ignition relay is now dead. No click when turning on the key also. I know you can swap out that relay for a regular 5 pin relay. Wondering if you guys can tell me what wire goes to what pin on the relay
I'm workin' on it
78 chassis with 75 cab
SBC
 Post subject: Re: ignition relay
PostPosted: Mon Mar 16, 2015 9:21 pm
There is no ignition relay on a LUV. It's just fused key on power. The wiring diagrams are in the info section of the site.
PostPosted: Mon Mar 16, 2015 9:39 pm
Hei power wire is the black/yellow stripe wire that I believe went to the factory coil. When following the wire back it goes right into the "Resistor bypass relay" No fuse
I'm workin' on it
SBC
PostPosted: Mon Mar 16, 2015 9:55 pm
On the 78 the black and yellow wire does not go to the by pass relay, it does power part of the fuel pump relay by the by pass relay. That doesn't matter, it's just T'ed off of it. No realy gives it power, it's comes off f the fuse box that is powered by the key switch. Have a look at the wiring diagram, it's all there. I would start with a test light for power at the fuse box and work forward or backwards beep ending if you have power. I can be of much help if you don't read the diagram and understand it.
PostPosted: Mon Mar 16, 2015 10:17 pm
Interesting. When it was a 1.8 the black/yellow wire went to the coil and or Resistor, memory a little foggy. It goes right into the Resistor relay, (it does T off before the relay) then there is a separate black/yellow going to the fuel pump relay. The truck has been working fine without a problem for 9 months till now. If I use a jumper wire from the + post to the hei truck fires right up. I'll play around with the test light a little more
I'm workin' on it
SBC
PostPosted: Mon Mar 16, 2015 10:35 pm
Checked wiring diagram traced it back to the fuse block, turns out that wire goes to the regulator and The heater/back up fuses. Put a fuse in the regulator spot (hasn't been a fuse there for 9 months and replaced the heater fuse which was bad. Truck is back up and running. Thank you luvrv8
I'm workin' on it
SBC
PostPosted: Mon Mar 16, 2015 10:45 pm
Nice work. Now you know the circuit, you will be able to help the next person.
PostPosted: Tue Mar 17, 2015 9:32 pm
Consider the relay anyways. I have one on mine because it wouldn't start cold on some days. Now I have real strong clean spark and it has helped my mileage.
PostPosted: Tue Mar 17, 2015 9:34 pm
Now that I look at your set up its so different than mine it doesn't relate.
Users browsing this forum: Bing [Bot] and 41 guests
