It is currently Fri Mar 27, 2026 12:57 pm
 Post subject: LUV & S-10 BED?
PostPosted: Mon Dec 29, 2003 9:44 pm
Has anyone put an s-10 bed on their luv? It's the same measeurments and all if i meseured right but i was wonder what it looks like. My bed is dented to all get out and it cant have tail lights in the original spots so i figured i'd put an s-10 bed on till i have to fabricate a flat bed. It's an 80's s-10 bed.
Thanks Derrik
PostPosted: Mon Jan 05, 2004 12:58 pm
May work. You might have to do some adjustments on the frame, but I would go look at the mount points on the S-10 bed first, then measure the distances and then re-visit the LUV and see if they match and what you have to do to make them fit.
PostPosted: Fri Jan 09, 2004 12:32 am
u going to have one ugly looking luv
PostPosted: Fri Jan 09, 2004 10:12 am
This has me thinkng. What about taking one of those sport side beds and cutting the wheel wells out of it and a luv bed and swapping the luv wheel wells to the s-10 box so they match the front. The way the box sides are set in on those, maybe the top bodyline difference wouldnt be so noticeable. Just a thought.
PostPosted: Fri Jan 09, 2004 10:22 am
You might be on to something. If someone does it, let me kno how it worked out.
PostPosted: Fri Jan 09, 2004 10:57 am
What about a bed from an 80's Isuzu P'UP or Yota if it's only temporary? :idea:
PostPosted: Fri Jan 09, 2004 11:23 am
I don't think that would work cause they are two different models, you can try if it bolts align up, but I don't think they will.
PostPosted: Fri Jan 09, 2004 12:39 pm
Gotta line up better than the S-10 bed.
PostPosted: Fri Jan 09, 2004 11:13 pm
If ya got a sawzall and a welder, you can made anything fit.
PostPosted: Sat Jan 10, 2004 9:46 pm
Hey thanks for the input and yes i was thinking that it would look pretty ugly. But luckly today i found a junk yard with 4 complete luvs in it that is what i could see from the opposite side of the fence wo knows there could be more. So i am going to go check that out next weekend.
Thanks Derrik
Users browsing this forum: No registered users and 116 guests
