It is currently Sun Jun 28, 2026 12:58 pm
Post new topic Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Feb 14, 2015 9:42 pm
Looks killer.....
PostPosted: Fri Feb 27, 2015 11:13 pm
Here is some more.
Working on the cold side now
After trying to figure out how to route the piping to the intercooling in the bed, we tried to keep some leg room.
But opted for the simpler look running the piping through the center of the floorboard, and the passenger will have warm feet instead of warm thighs.
Here is the intercooler being mounted in the bed.
Starting to get close to completing the turbo kit. I am amazed at how its turning out.
PostPosted: Sat Feb 28, 2015 4:09 pm
Nice work.
PostPosted: Mon Mar 02, 2015 5:35 pm
Going to have it ready for Dig Night?
PostPosted: Mon Mar 02, 2015 9:00 pm
I don't think so. I am hoping to have it running but won't have the bugs worked out by then. I also still have to put the finishing touches on the Blazer and do some testing so that will take precedence over the Luv for this race.
Here's a photo from today.
PostPosted: Tue Mar 03, 2015 5:51 am
Where is dig night this year? It that the one at the airport?
PostPosted: Tue Mar 03, 2015 8:01 am
Not the airport this year. Heard it was on concrete this year. He won't give the location up till Thursday or Friday before the race to keep people from testing there.
PostPosted: Sat Apr 11, 2015 11:49 am
How are you controlling your 4l60e? That is a electronic transmission controlled by the ECM. Are you manually shifting it through all the gears? ECM also control's the torque convertor lockup
PostPosted: Tue Apr 14, 2015 8:15 pm
I had a Rossler black box controlling the transmission. It made it a full manual but allowed me to lock the converter up till with a button. I am now controlling it with the Holley EFI system.
PostPosted: Tue May 12, 2015 5:50 pm
How is it going? Seen a bit about it on a post at Facebook.
PostPosted: Tue May 12, 2015 9:58 pm
She's running. Still breaking everything in on a base tune but just on the Wastegate spring (5lbs) it feels good. I turned the C02 bottle on just to see what kind of boost it will make and it pegged my 3bar MAP sensor out. Once I get it lined out it should run decent.
PostPosted: Wed May 13, 2015 3:04 am
Your not at the E 85 pump ?
PostPosted: Wed May 13, 2015 5:21 pm
well yes, the yellow handle is E-85 but I am on 93. My fuel system isn't going to be enough for E-85 so I am on 93 until I add another pump and bigger injectors. Highest I have seen the duty cycle so far is 54% but haven't really made any hits longer than one gear.
PostPosted: Thu May 14, 2015 2:33 am
I figured with Garrett involved it wouldnt be long before pump E85 was in the tank . And once you make the switch you'll never look back . That Holley dash is awesome.
PostPosted: Fri May 15, 2015 1:40 pm
LSX LUV Owner
Truck is looking good. I follow you on instagram. Im right down the road from you, I pass that station all the time. I think i actually met you yearssss ago at garrets house then we all went out to Galveston.
PostPosted: Fri May 15, 2015 6:34 pm
If you're ever bored in the 'Fe swing by the shop. We are always out there tinkering with something.
