It is currently Sun Jun 07, 2026 5:13 am
PostPosted: Sun Feb 01, 2015 11:35 am
My truck starts fine but when I let off the ignition switch it dies. Replaced alternator voltage regulator and tried different fuel pump relay same results. Guess there is a bad wire for the fuel pump relay , any ideas/advice. Thanks
PostPosted: Sun Feb 01, 2015 12:03 pm
You're not supposed to wire the fuel pump to the ignition because if you get in a wreck the fuel pump will keep running but you can do this to make sure it's a wiring issue on that circuit and keep it until you figger out the proper wiring. Someone on here will know better than me but I think the power should come from the alternator.
PostPosted: Sun Feb 01, 2015 12:19 pm
I agree it's wired that way from factory it seems there are two conditions starting and running. My truck starts but doesn't stay running.
PostPosted: Sun Feb 01, 2015 6:26 pm
Because the start circuit also gives power to the fuel pump because the alt isn't turning fats enough to power it while cranking. So your truck will run for a sec after it starts and then run out of fuel.
PostPosted: Sun Feb 01, 2015 6:33 pm
It dies as soon as he lets off of the starter. If it was a fuel pump issue it would run until the fuel burns out of the carb, that would be a couple minuets. He has a electrical issue with the ballast or wiring to the coil.
PostPosted: Sun Feb 01, 2015 6:48 pm
When I had that problem it died pretty quick.
PostPosted: Sun Feb 01, 2015 7:41 pm
There should be enough fuel in the bowl to idle close to a minuet at idle, if not your float is way too low.
PostPosted: Mon Feb 02, 2015 8:41 pm
Figured it out. I just happened to notice when I was cranking it over the radio didn't come on. Actually after testing nothing worked in the run mode on the switch. I took the switch out and it was cooked , must have been losing power in the rub mode. Thank you for your help and ideas. Ryan
Users browsing this forum: Bing [Bot] and 35 guests
