It is currently Sun Jun 07, 2026 5:15 am
PostPosted: Tue Jan 27, 2015 6:43 pm
If you saw my last post, you know i blew a head gasket. I blew a head gasket because an old hose cracked and leaked a good majority of my coolant out. I didn't know the coolant was gone and the engine was overheating because my temperature gauge (once i turn the vehicle on) automatically tops out all the way to the right passed the "H" . When I turn the truck off, the gauge immediately flips back to the left and passed "C" . Has anyone seen this problem before? I am about to make the drive from Greeley back to Kansas city (in two weeks so i have some time) and I'd like to be a little more confident in my vehicle. I'm also going to town tomorrow to get some new hoses. Probably should have done that a long time ago but why not wait until it costs me $200 right? Any help with the temp gauge/sending unit is appreciated it! I will keep searching the site for some sort of answer. Could be a thermostat problem?
PostPosted: Tue Jan 27, 2015 7:51 pm
Sounds like the temp sending unit wire is grounded out. Make sure it's connected good to the sending unit. Mine did this once and I had blindly slipped the connector on to a stud beside the sending unit. The sendng unit is under the intake manifold.
PostPosted: Tue Jan 27, 2015 8:58 pm
The wire to the sending unit doesn't appear to be grounded anywhere, at least not on the engine side. If i detach the yellow and black wire from the TSU, it immediately goes back to "C". Could there be something faulty inside the TSU that would be grounding it out internally? I will probably take off the instrument panel out tomorrow to see if perhaps i've grounded it in there somehow. I'll save the cussing and finger skin for then i guess. I took a few pictures with my (ghetto) walmart phone so they are kind of crappy but here's what i am looking at. As you can see the wiring job isn't exactly top notch but it definitely doesn't seem to be wired to a grounding location anywhere.
EDIT: Am i hooked up to the "oil pressure sending unit" instead of the temperature sending unit? Hell, they might be the same thing for all i know. I am just researching, walking outside and testing, coming back inside, researching, walking outside and testing... so on and so on...
PostPosted: Tue Jan 27, 2015 10:30 pm
Yeas, that is the oil pressure sending unit.
PostPosted: Tue Jan 27, 2015 10:34 pm
The temp sending unit points down from the intake manifold. It's kind of hard to see. It's vertical.
PostPosted: Tue Jan 27, 2015 10:36 pm
Like drummer said, it's under the intake. It's on the front half of the intake below the thermastat.
PostPosted: Tue Jan 27, 2015 10:53 pm
I'll have to give it another gander tomorrow in the daylight, couldn't seem to find it tonight. Hell, maybe I don't even have one!
PostPosted: Wed Jan 28, 2015 4:08 am
Temp unit should be a yellow wire w/black stripe. Oil pressure is yellow wire w/white stripe.
PostPosted: Wed Jan 28, 2015 10:30 am
Found it, fixed it, works great. Thanks for the help!
Users browsing this forum: Bing [Bot] and 35 guests
