It is currently Wed Jun 24, 2026 5:22 am
PostPosted: Sun Jan 11, 2015 6:55 pm
Hi Y'all,
I read the other "1980 conversion" thread and will be reading Eric's 75 conversion thread next.
But first,
can you identify this motor? the 2.2 or the 1.8?
I attached the pics.
My story:
I have a 80 4x4 LUV and got a parts truck, a 79 4x4 diesel conversion that looks like shit but the motor, tranny, and transfer case runs. it drives.
I'm hoping to just have to swap the motor, but it seems like if it's the 2.2 I will have to swap tranny and xfer case too (because bolt pattern on 4sp tranny is diff?).
After I read Eric's conversion thread I will post other questions I have here, but first I'd like to know if any of yall can ID my diesel motor : )
thank you!
PostPosted: Mon Jan 12, 2015 1:50 pm
zster wrote:
But first,
That's a 2.2L C223. If it's with the original radiator, I'd say it's a 1984 or 1985.
The box on the back of the valve cover, with hoses on it--that's a feature that came in '84.
In '86, they got a smaller filler neck. The radiator looks like it has the larger cap, which means it's pre-1986 if I'm right.
PostPosted: Wed Jan 14, 2015 5:18 pm
Wonderful, thank you.
Now I am wondering how I can find out the differential gear ratio on the diesel and on my gasser... its not written on there.
I have no idea if the radiator is stock or not....
PostPosted: Thu Jan 15, 2015 9:43 pm
The diesel would have had 4.10 diffs if it was 4x4. I don't know about the '79 and '80 trucks, but someone here should know.
PostPosted: Sat Jan 31, 2015 6:45 pm
Project is well under way!
I am wondering if I need to change out fuel lines for the diesel?
and if I can keep the electric fuel pump next to the tank? Or do I need to upgrade it for a thicker fuel?
thank you!!
(Sorry I tried searching for the answer but couldn't find it)
PostPosted: Sat Jan 31, 2015 7:46 pm
All 4x4s came with 4.10 gears
PostPosted: Sun Feb 01, 2015 10:42 pm
I'd change the fuel lines just because they're old. Any fuel line leak will cause the truck to run really badly, if it even runs at all.
These diesels don't require a fuel pump, other than the injection pump on the engine.
PostPosted: Sat Feb 28, 2015 8:55 pm
Hey folks!! new question, couldn't find the answer by searching.
So everything's workin ok with the diesel and ive put about 600 miles on it. :)
but still haven't figured out how to get a diesel nozzle in the hole meant for the gas nozzle.
so i've been putting a few gallons in at a time and i'm getting really bored of that.
What have other folks done when they've done a 1st gen conversion?
should i drill the whole bigger??
orr....???
thanks!!
PostPosted: Sat Feb 28, 2015 9:18 pm
I may have an extra diesel filler neck, but I'm not sure if you'd need it, and not sure it would even fit the 1st gen bed. Maybe someone else who's done the conversion can help, as you requested. But I'll ask around anyway.
PostPosted: Fri Mar 06, 2015 12:36 pm
thanks jack. maybe I should even post this on your site cuz its more active.
I wonder if there's any way we could know that your extra filler next would or wouldn't fit? (before I have it in my hands)
I was also wondering what "that box with the hoses" on top of the motor is.
my alternator is apparently from the 81-83 motor...? according to dart sq. confusing!
I obviously need to buy a manual :)
PostPosted: Fri Mar 06, 2015 4:08 pm
Besides the box on top of the valve cover with hoses (it's an oil separator, by the way)--
There was another change in '84. The oil filter base is rounded on '81-'83 engines, and square on the '84-'87 engines. The '84 and later engines got a larger oil filter that's not interchangeable with earlier ones.
PostPosted: Fri Mar 06, 2015 5:47 pm
The exhaust manifolds were changed (improved) in later years but I don't recall the exact year. Supposedly freed up a couple HP's. Jack can you clarify?
Tom
PostPosted: Sat Mar 07, 2015 8:19 am
Tom, that was '83--the manifold outlet got enlarged.
PostPosted: Fri May 29, 2015 8:28 pm
Great to hear of another 1st gen diesel Luv!!
I'm still using the stock gas filler neck but our local station has a diesel pump for cars and light trucks.
PostPosted: Sun May 31, 2015 8:39 am
Keep in mind that if you switch to a diesel filler neck that you'll need to use a basically impossible to find diesel fuel cap. If you enjoy the sound of crickets chirping, try posting "Need a diesel fuel cap".
Tom
PostPosted: Sun May 31, 2015 1:07 pm
Tom, do you need one? When I had one spare, I wasn't willing to part with it. Now I have two (one came with the bed I bought).
PostPosted: Sun May 31, 2015 1:47 pm
Yes sir, I do! Thanks Jack!
Tom
PostPosted: Mon Jun 01, 2015 8:26 am
Tom, I'll email you when I find it.
PostPosted: Fri Jun 26, 2015 11:50 am
Great to see another 1 gen Luv diesel!!! Anymore pictures of it?
I would love to put my diesel in my 4x4 but since it came with the 2wd T5 I just put it in the 2wd.
