It is currently Thu Dec 18, 2025 2:44 pm
 Post subject: Valve Cover torque?
PostPosted: Wed Jun 19, 2013 1:57 pm
I just replaced my valve cover gasket, and i torqued the bolts to ten feet pounds for now, but does anyone know what they should be at? i have a manual and it doesnt have the specs for the valve cover.
'78 2wd LUV, Betsy, THE LUV MACHINE
 Post subject: Re: Valve Cover torque?
PostPosted: Wed Jun 19, 2013 8:35 pm
I have always just tighten them tight, I have never torqued a valve cover. I do think there is a torque value but most of us just use common sense.
PostPosted: Wed Jun 19, 2013 10:22 pm
Alright thanks
PostPosted: Thu Jan 08, 2015 10:19 pm
How easy was it to replace ur valve cover gasket?
PostPosted: Fri Jan 09, 2015 8:06 pm
I'm not OP but it's easy man. Maybe one of the easiest gaskets to replace on a car.
Anyhow,
1. Unscrew bolts and remove cover
2. Peel off old gasket
3. Wipe mating surfaces
4. Place new gasket
5. Replace cover
6. Re-tighten bolts
