It is currently Sun Jun 07, 2026 9:49 pm
PostPosted: Fri Nov 21, 2014 11:31 pm
will this work for electric dust. conversion for my 79 LUV? from a late 80's isuzu impulse with the 1.9 engine.
PostPosted: Sat Nov 22, 2014 12:04 am
will this electric distributor work? clean and fully tested and functional electronic distributor from a late 80's isuzu impulse with the 1.9 engine. Will fit many nissan and datsun engines as well
PostPosted: Sat Nov 22, 2014 12:31 am
If anyone has installed it or knows they would respond to the first post you have on this. A mod will be around soon to delete one of your posts. In the future please one post per question.
PostPosted: Sat Nov 22, 2014 5:33 pm
i cant tell you for 100% sure
but these are the equivalent part numbers for the one I used from an 85 Isuzu trooper 1.9 I pulled these off of rockauto.com 8942537440, 8942537441, 8942537450
I cant say for sure that these not matching up to that distributor meaning that it wont work, but it isn't the same as what I used. it looks a bit different on the plug and the vacuum diaphragm on that one isn't pictured so I cant compare them
the one I used is currently $136 on rockauto remanufactured by cardone. the pertronix is cheaper unless you get the 85 trooper dizzy on sale or from a yard. since there are no points to wear out a used one should be just fine try ebay
PostPosted: Sun Nov 23, 2014 9:46 am
I think it will. I have a 1.9 in my luv and they all have the same dist.
I think I even have a spare one that I ran in a 1.8 I'd sell if it doesn't work.
PostPosted: Sun Nov 23, 2014 1:11 pm
it should drop in im looking at one out of an 87 on rockauto and it says its a g200 so should drop right in same as the one I had. the 2.0 that wouldn't fit has a shorter thicker shaft and a different cap from what I can see on rockauto
PostPosted: Sun Nov 23, 2014 3:37 pm
Does it have a wire harness with a plug on the end of it? You will need the control box that mounts to the coil also, to make it work.
PostPosted: Tue Nov 25, 2014 9:01 am
Their are several posts on newer factory distributors including any wiring changes needed.
http://forums.luvtruck.com/viewtopic.php?f=40&t=28970&hilit=distributor+swap
Use the search on distributor swaps
Users browsing this forum: Google [Bot] and 61 guests
