It is currently Sun Jun 07, 2026 5:59 pm
PostPosted: Wed Nov 05, 2014 4:18 pm
There is a large hose and a small hose on the valve cover that have vacuum into the intake that I believe are sipping oil. One of the lines is clear and I can see oil in it.
What have you guys done to stop this?
PostPosted: Wed Nov 05, 2014 6:44 pm
It is the normal engine ventilation system. Large hose takes filtered air into the engine, small hose takes oil/gas fumes from the engine into the intake manifold for consumption/burning. A bit of oil/vapors will be normal but a worn engine will consume much more.
