It is currently Sun Mar 29, 2026 6:49 pm
PostPosted: Sun Aug 31, 2014 1:19 am
Any one given any thought to putting a wood floor like they do on some older trucks. I know you can buy the strips that go between the boards. Whole kits.
Would you cut most of the floor out? Or put it on top of the floor. Bel liners can make for a rusty floor years later down the road. Duraliner the bed floor then do the wood over it? If I had a bed with a bad floor I think I would try to do this.
PostPosted: Sun Aug 31, 2014 5:29 am
For a nice driver or a show truck I think it would look really cool. Its not cheap and you would have to do a lot of fabrication.
PostPosted: Sun Aug 31, 2014 9:27 am
Cutting the floor out would be a huge job. Working with my trailer project I found every rib of the bed floor is welded to the cross beams. Not that it couldn't be done, there would be a ton of cutting and grinding. Laying the wood on top would be much easer. If you seal it good and maybe add a tonneau cover it should last a while.
Users browsing this forum: Bing [Bot] and 7 guests
