It is currently Sun Jun 07, 2026 7:11 pm
 Post subject: Dash pad
PostPosted: Thu Aug 07, 2014 8:46 am
New to the Luv world...how do I get a dash pad?
Joel
 Post subject: Re: Dash pad
PostPosted: Thu Aug 07, 2014 10:18 am
Ongoing thread somewhere on here about someone reproducing them someday. Until then the only readily available option is the plastic dash cap to cover the upper part of your dash. Occasionally a NOS one pops up, be prepared to spend a LOT if it does...
PostPosted: Fri Aug 15, 2014 9:17 am
I've seen a few "Dash Caps" on ebay,,, they say they fit LUV dash, but I can't just go down & check em out coz I'm in AUstralia,,, have any of you USA based guys used one of these "Dash Caps"?
With a gas axe & slide hammer anything will fit :)
PostPosted: Fri Aug 15, 2014 3:27 pm
Most of us have. I got one on mine, if the bottom of yours is good you won't notice it on there...
PostPosted: Fri Aug 15, 2014 11:24 pm
Cheers for your reply,,, any chance of a photo of one fitted?
PostPosted: Fri Aug 15, 2014 11:57 pm
Only crappy pic I have at the moment...
PostPosted: Sat Aug 16, 2014 4:55 am
Still doesn't look too bad,,, what about the dash grille, are they pretty hard to get as well?
PostPosted: Sun Aug 24, 2014 7:02 am
http://www.autoanything.com/dash-mats/60A4600A0A0.aspx have had it for 5 years, still looks new
Perception is 9/10 of the flaw
PostPosted: Wed Oct 08, 2014 11:13 pm
I have two dash grilles right now. Both are in good shape although if I remember right one is a bit fragile. I want to use one of them for my truck, but I'm willing to sell the other.
Hannah - '79 4WD, 32/36 Weber, and a Pacesetter header. :D
PostPosted: Sun Nov 02, 2014 6:47 am
I ordered my new dash cap on Thursday,,, should arrive around the 10th Nov :P
