It is currently Fri Jun 19, 2026 1:26 pm
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: 89' S-10 5.3
PostPosted: Fri Aug 22, 2014 7:44 pm
Very nice!! :smt023
PostPosted: Fri Aug 29, 2014 5:28 am
Pulled the trans yesterday . Old converter campaired to the new one .
PostPosted: Fri Aug 29, 2014 10:56 am
I spy a spark plug, fender shim, u bolt, 9 inch backing plate bolt, and what looks like the top for a butane powered soldering iron in the paint job...
PostPosted: Fri Aug 29, 2014 2:10 pm
No duplicate to that pattern ever . Made from scratch . Almost wish i had done wrenches .
PostPosted: Fri Aug 29, 2014 3:44 pm
or a tq wrench somewhere in there
but it looks pretty epic as it is I wouldn't change a thing about it
PostPosted: Fri Aug 29, 2014 7:37 pm
Thanks i wouldnt either . Today was good . I bought a 55k 6.0 from a low mile 2002 van with everything . I also bought a pair of 243 heads ( C5 Z06 ) for $100 each from my machinist with 12,000 miles . So 6.0 , 243 heads , 224r cam and 3200 converter . should make 425 or so we will see .
PostPosted: Fri Aug 29, 2014 8:13 pm
one fine Dime!
PostPosted: Fri Aug 29, 2014 9:41 pm
I am looking at the 6.0 deal too. Here is what I am looking at, this is in a friends 59 Chevy Wagon.
PostPosted: Sat Aug 30, 2014 4:48 am
Super charger and A/C , nice .
PostPosted: Sun Aug 31, 2014 6:15 am
Trans ended up being pretty worn . I looked everything over . Replacing the plastic pistons , all the aluminum bushings . Wide band and new drum , upgraded sun shell . shift kit , servo upgrade . And fresh soft stuff of coarse Should have it back tonight for reinstall . Around the 1K mark , but i am getting to see all the parts go together . I always hate trans work . Leary of people selling stock stuff to you after paying for good parts .
PostPosted: Thu Sep 04, 2014 4:40 pm
Well got it all in today and running . Converter will go 1800 on the footbrake so 3200 seems correct . It will probably only be 2600-2800 rpm flash in the light under powered truck , but it'll work good good behind the 6.0 later down the road . Trans is solid .
PostPosted: Wed Sep 17, 2014 7:46 am
Axles showed up , i have the heads in the machine shop right now . Pulling the valves out of the 317's and putting them in the 799's after a surface job and valve springs .
