It is currently Thu Mar 19, 2026 7:55 am
PostPosted: Tue Jun 24, 2014 12:48 pm
I have a 1980 with the factory 1.8l. I am looking at this radiator unless there is one better recommended:
http://www.ebay.com/itm/19-x22-Ford-Sty ... aa&vxp=mtr
Will this radiator be fine with the factory fan and also does anyone have any good pictures of one installed?
PostPosted: Tue Jun 24, 2014 1:23 pm
Why not just get your factory one rodded? A lot of people run a 19x22 radiator, myself included but we have sbc swapped in place of the 4 banger. You'll have to cut out some metal for it to fit
I'm workin' on it
78 chassis with 75 cab
SBC
PostPosted: Tue Jun 24, 2014 1:41 pm
The radiator I have will run $270 to get rebuilt. I plan on making this truck a daily and would like to use it for some trips as well so I want to maximize cooling. I don't mind doing some cutting, I work with metal often.
PostPosted: Tue Jun 24, 2014 2:18 pm
How will it mount? The stock rad has side flanges that bolt to the fan side of the supports, the one you have chosen probably fits into a padded channel.
PostPosted: Tue Jun 24, 2014 2:22 pm
Alright this can be deleted. I did some research. I am going to go with a Griffen 1-26182-XS radiator and will cut as little as possible. I plan on welding a channel on the bottom that is rubber lined and make a bolt in channel up top that will hug the radiator. Should provide plenty of cooling and get this thing where I need it to be. Head has been overhauled, all new gaskets, next is the radiator and weber carb.
PostPosted: Tue Jun 24, 2014 7:22 pm
Post some pics when you get it done.
PostPosted: Tue Jun 24, 2014 7:41 pm
check out my build thread I installed a 19x22 rad by widening the channels beside the radiator to fit it and make it look semi stock with a c channel under the radiator and tabs near the top to hold it in
PostPosted: Tue Jun 24, 2014 8:11 pm
Thanks, I will post pictures and definitely check out your thread.
Users browsing this forum: Bing [Bot] and 23 guests
