It is currently Tue May 26, 2026 4:31 am
PostPosted: Tue May 13, 2014 1:25 pm
Hello everyone, I'm rebuilding my stock carb. any tips?
1979 Chevy luv Mikado 1.8 4 speed 4x4
PostPosted: Tue May 13, 2014 4:50 pm
Be very carful. Pay attention to the details when disassembling it. These are very hard carbs to rebuild. Take pictures of the rods and what hole they are in.
PostPosted: Tue May 13, 2014 4:58 pm
I started to take it apart then I wasn't sure if its even the stock carb. It doesnt have a round glass eye on the float. its a glass window. the float does say 340 on it. The gaskets look the same but I think i'm going to change the filter and fuel pump before I attempt the carb rebuild. i was intimidated by the number of little pieces in the kit. Thank you for the reply.
PostPosted: Tue May 13, 2014 8:31 pm
there are a couple stocks carbs. i know there is a dch 340 and a dcp 340 not sure of the differences but i had both at one point.
PostPosted: Wed May 14, 2014 6:55 am
If u cant do it yourself try this company
Recarbo Carburetors II
661 Garcia Ave, Pittsburg, CA 94565
(925) 439-7030
PostPosted: Wed May 14, 2014 12:03 pm
I rebuilt the stock carb, wasn't all that difficult but time consuming.would be easier to buy a weber, and gain a bit of power too
I'm workin' on it
78 chassis with 75 cab
SBC
PostPosted: Wed May 14, 2014 3:33 pm
I had mine rebuilt for 100 bucks. Came with free carb tuning for the following year.
...which meant I went back to him every time I did something to the truck during the initial 'figuring-out' and 'upgrading shit' phases of buying an old vehicle.
The price was well worth that particular perk. Mostly, it helped me rule out "Do I have it tuned right?" while troubleshooting other problems I hadn't solved yet.
PostPosted: Thu May 15, 2014 12:09 am
Yeah I have fuel overflowing from the float breather vents. At a lost. How do I feel it?. Lol
PostPosted: Fri May 16, 2014 1:04 am
Fuel overflowing means: #1-- float level incorrect, needle valve sticking, missing.
#2-- fuel pump wrong pressure, spec is 3-4 lbs.
Users browsing this forum: Bing [Bot] and 78 guests
