It is currently Thu Jul 16, 2026 5:49 pm
Post new topic Reply to topic  [ 217 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10, 11  Next
 Post subject: Re: my 78 luv build
PostPosted: Tue May 06, 2014 10:55 am
some pics.. got everything ready to go in last night but didn't have the torque converter bolts and id rather put those on now then while laying under the truck.
I'm workin' on it
78 chassis with 75 cab
SBC
PostPosted: Tue May 06, 2014 10:25 pm
Motor and tranny are in, carb is on, driveshaft is on but still gotta bolt that down, Speedo and shifter cables hooked up. Off to oreillys again tomorrow for some engine mount bolts, and radiator hoses. Getting the driver side bolt to go through the mount was a PIA.. welded on the gussets for the mount a little crooked. I'm sure it'll be fine, might eat through motor mounts though.
I'm workin' on it
SBC
PostPosted: Thu May 08, 2014 8:23 pm
Driveshaft bolted up on, motor bolted down, topped off the engine and tranny fluids. Just need a starter, some pulleys and belt, alternator and mount, radiator hoses and fill it up with coolant and ill be able to fire it up. Exhaust would be nice too but I can wear ear muffs for a while :)
I'm workin' on it
SBC
PostPosted: Tue May 13, 2014 10:18 pm
Not much happening lately.. ordered stainless steel flexible radiator hoses today, bought some starter bolts and bolted up the water pump yesterday.
I'm workin' on it
SBC
PostPosted: Wed May 21, 2014 5:44 pm
Radiator hoses will be here tomorrow, and I've got some chrome water pump, and crank pulleys, along with a chrome alternator mount that'll be here next week. Still need a starter, alternator and some plug wires to fire it up. Almost ready for some summertime cruisin! :)
I'm workin' on it
SBC
PostPosted: Thu May 22, 2014 10:21 pm
Top radiator hoses are all finished up, lower hoses are cut but need to get a section of hose that'll fit over the water pump and a reducer... Looks alot Better than rubber hose and they should last a vert long time. Will throw up some pics later.
I'm workin' on it
SBC
PostPosted: Thu May 22, 2014 11:12 pm
very nice cant wait to see it i love the look of braided hoses
PostPosted: Fri May 23, 2014 3:03 pm
heres a pic... wish I woulda gotten the braided socks for the hoses but I couldn't find the right shade of purple or orange.
I'm workin' on it
SBC
PostPosted: Fri May 23, 2014 9:00 pm
It looks like its ready to have some fun with. 8)
PostPosted: Fri May 23, 2014 9:50 pm
Just about! Pulleys will be here next week, need to get a starter, belt and alternator, drop in the dizzy and it'll be ready to fire up. Still trying to figure out a throttle cable setup
I'm workin' on it
SBC
PostPosted: Fri May 23, 2014 11:06 pm
Looking good. I built my LUV almost 9 years ago. I still have a couple things I need to do that I put off just to get it running. Try to button up all things or you might be like me and keep putting things off.
PostPosted: Fri May 23, 2014 11:28 pm
Thanks man! The plan is to finish up everything before I drive it, besides the exhaust. Going to try to go 3" exhaust and want a quiet tone that has a nice growl when you get on it. I have borlas on my jaguar and they sound amazing, Idk how they would sound on a v8 though
I'm workin' on it
SBC
PostPosted: Fri May 23, 2014 11:36 pm
Borla sound great with a V8. They are made in the next town over from me. The owner is a nice guy and his products are top notch. He owed a friend of mine a favor and my friend got his guys to build a header for my Dwarf Car. That was 15 years ago and those headers are still on a dirt race car.
PostPosted: Sat May 24, 2014 3:25 pm
Good to know, those will probably be what ill go with. Got all my pulleys and alternator brackets today. Crank pulley is on, just waiting on the 4 chrome water pump bolts for that pulley. Still gotta do the lower radiator hose, prime the motor and get a couple more parts. So close, can't wait to hear this thing run
I'm workin' on it
SBC
PostPosted: Mon May 26, 2014 12:32 pm
Looks like ill be running an electric fuel pump with regulator. Mechanical fuel pump was right in the way of lower radiator hose. It will look a lot cleaner too I think not having a bunch of hoses crammed together and potentialy causing leaks. 1 step forward 2 steps back. Oh well its getting there
I'm workin' on it
SBC
PostPosted: Mon May 26, 2014 6:49 pm
Bought a chrome fuel pump block off plate today, along with a starter and ordered an orange aluminum fuel pressure regulator that'll be here the 2nd. I also filled up the radiator with coolant. Just waiting on water pump pulley bolts, fpr. and I still need to get an alternator and electric fan, but I don't need those to fire it up and run it for a little bit
I'm workin' on it
SBC
PostPosted: Tue Jun 03, 2014 5:41 pm
Not a lot happening really.. just trying to finish up all the small things. All I need to do is drop in the distributor to fire it up, might do that today. I pre-registered for the billetproof car show which is the 28th, so I surely hope it'll be all good to go by then. I drove the truck there last year with the 4 banger, would be nice to make it this year with the v8. All that's left is alternator, electric fan, belt, throttle cable setup, shorter carb stud and intake manifold vacuum T.
I'm workin' on it
SBC
PostPosted: Thu Jun 05, 2014 1:00 am
Fired it up tonight!!!! Thing sounds freaking good!!! Even with no exhaust haha. Only got to run for a couple seconds, my fuel pump is dead, and I dont have a belt or alternator yet. It's a good healthy motor, good oil pressure no smoke. So close, was definetly really good to hear this thing run finally
I'm workin' on it
SBC
PostPosted: Thu Jun 05, 2014 5:19 am
Man I`m jealous mine is so far away. Looking nice.
PostPosted: Thu Jun 05, 2014 11:48 am
Thanks! Still need just a few parts, can't wait to drive this beast!
I'm workin' on it
SBC
